Engine light Hell!
Old May 15, 2005 | 09:03 PM
jagbits's Avatar
jagbits
Default RE: Engine light Hell!
With all the CAI kits on GT's I can't believe that I am the only one with this problem, sucks ***!
Old May 18, 2005 | 12:30 PM
Mach69to05's Avatar
Mach69to05
Your UD pulley isn't sitting right on your crank shaft, there is some kind of sensor for vibrations, this has been a common problem with the underdrive pullies. Especially seeing it was the last upgrade you did.
Old May 18, 2005 | 04:46 PM
jagbits's Avatar
jagbits
I think the same thing, I took it off and put it on a 2nd time but I still got the light. I think the bottom pulley is defective. I'll let you know what happens thanks for the help.
Old May 18, 2005 | 07:39 PM
jagbits's Avatar
jagbits
I just got off the phone with Steeda and they told me to remove the crank pulley and re-install following the directions again, they said if the pulley is not seated perfectly it will cause a light vibration and it will activate a sensor, probably the crank sensor, and throw an engine light, so I will do as I'm told and pray for success.
Old May 18, 2005 | 08:07 PM
don_w's Avatar
don_w
I ♥ Acer
Best of luck to you!
Old May 18, 2005 | 08:29 PM
jagbits's Avatar
jagbits
Thanks Don. If it keeps happening he said I can put my old pulleys back on and return the Steeda pulleys for a new set or refund, I think a store credit will be fine!!
Old May 18, 2005 | 09:54 PM
lostsoul's Avatar
lostsoul
yea.. good luck.. I dont know about the "read the manual" part.. but... let us know what happens
Old May 18, 2005 | 11:08 PM
flyingt's Avatar
flyingt
I hope everything works out.
Old May 19, 2005 | 07:37 PM
BRENSPEED's Avatar
BRENSPEED
Former Sponsor
ORIGINAL: lostsoul
If you are still fighting that and want to try the stock air box with a tune give me a call. That would at least rule out the Steeda air intake. Or just stick the stock pulleys back on...
Give me a call if you need help.
Old May 20, 2005 | 01:42 PM
jagbits's Avatar
jagbits
Brent i didn't want to bother you yet, I have a strong suspicion that the pulleys need to be taken off and re-installed again. I will call you if i figure it out. It's been 5 days and the light has not come back on yet.
djbigskrilla
Sep 20, 2022 01:04 AM
J.casone400
Aug 28, 2015 09:33 PM
kevans79@yahoo.com
Aug 18, 2015 08:16 AM
mweiland
Aug 13, 2015 05:11 PM
drumhedd2005
Aug 13, 2015 09:59 AM
