Car won't start
Old Aug 31, 2008 | 07:21 AM
downriverT's Avatar
downriverT
Default Car won't start
The last few times I have drove the car it just grind before startup. Now thats all it will do. Doesn't even start to crank over. Is it the starter? The selenoid? How should i start on fixing this?
Old Aug 31, 2008 | 08:42 AM
Stoenr's Avatar
Stoenr
Is it a grinding noise for sure? When the batt is low and not enough to crank it makes a funny fast clicking noise that some might take as a grind. If it is grinding it could be the starter or the flywheel.
Old Aug 31, 2008 | 09:38 AM
downriverT's Avatar
downriverT
Yes its a grind. I got the car to start using the fred flinstone way. I push started it just to see if I could get some more info. What would the flywheel have to do with starting the car? I had to have it remachined and a new clutch put in this summer.
Old Aug 31, 2008 | 10:11 AM
Stoenr's Avatar
Stoenr
To my knowledge, which has alot left to be desired, the starter armature turns the flywheel, which starts the car.
Old Aug 31, 2008 | 10:27 AM
downriverT's Avatar
downriverT
definetely going to have to look into that. had alot machined off the flywheel.
Old Aug 31, 2008 | 10:36 AM
marcuskeeler's Avatar
marcuskeeler
A grinding noise during cranking is a sign of bad gear mesh between the flywheel ring gear and the starter pinion. That's kinda weird though because these starters are pre-engaged [I believe].
Having the flywheel skimmed is one thing, but I didn't think they skimmed the ring gear as well, that would be a bit silly IMO.
Old Aug 31, 2008 | 05:45 PM
mxg30's Avatar
mxg30
Believe it or not, this could still be a battery related problem. Always rule out the simple things first. If you are like most mustang owners and do not drive your car daily (especially if you have the factory battery) you may not be getting enough cranking amps through to the starter. It is possible to have 12volts but not enough cranking amps. This would put a strain on the starter trying to turn the flywheel which could give a grinding effect. Also if yu were ab le to push start and had no grinding or less grinding then more than likely it is the battery. Good Luck!
Old Aug 31, 2008 | 06:45 PM
downriverT's Avatar
downriverT
I noticed while I had it running that everytime I would give it gas I would get the exact same grind noise as when I would try and start it. Here is my abbr mod list
cai, tune, clutch, remachined flywheel, udp's, exhaust, yellow top battery. Its not a daily driver.
Old Sep 1, 2008 | 10:28 AM
max427's Avatar
max427
Wait did your problem start immediately after clutch n flywheel install? iirc on a GT flywheel the teeth are offset towards the engine, so technically it could have been installed backwards causing the teeth to be much further back. or vis-versa. That or, since the starter was removed maybe they either didn't tighten it all the way, leaving a gap between flywheel and starter or maybe cross threaded a bolt and couldn't tighten it all the way.
Do you notice any strange pulsation or chatter when coming from a stop easing off clutch into first gear? if so maybe the flywheel is installed improperly. A dealer with diagnose it for you if you'd like.
Old Sep 1, 2008 | 11:44 AM
downriverT's Avatar
downriverT
Well no but I don't drive the the car very often. It ran and started fine. It started to grind a bit a few weeks ago. Just got worse over time till it didn't work anymore.
