Help!!!
Old Aug 31, 2008 | 04:29 PM
rford426's Avatar
rford426
Default Help!!!
Nothing in my gauge cluster is working...the radio works fine and everthing else seems normal except my a/c does not blow cold and the gauge cluster is not lit up at all... The traction control also will not turn off...any suggestions?? It all happed after i tried pluggin in my sct tuner??? help me please
Old Aug 31, 2008 | 04:53 PM
rford426's Avatar
rford426
anything
Old Aug 31, 2008 | 05:29 PM
mxg30's Avatar
mxg30
Not too many aswers on this one. Try dis-connecting yor battery so that your computer can reset. Do you already have a tune installed or is it stock? if you are trying to install a tune, be sure that everything is turned off before you hook up. Good Luck!
Old Aug 31, 2008 | 05:45 PM
grampa_stang's Avatar
grampa_stang
Go to the passenger side kick panel and replace fuse #8
Old Aug 31, 2008 | 06:38 PM
rford426's Avatar
rford426
thank you soo much haha it was the fuse now my engine light is on the code was p2067 what is that exactyly and what do i need to do to get this taken care of
Old Aug 31, 2008 | 07:01 PM
kxl77's Avatar
kxl77
Gangster answer.
Old Aug 31, 2008 | 07:27 PM
downriverT's Avatar
downriverT
well have no idea what it means but the code says fuel level sensor b low
Old Aug 31, 2008 | 09:58 PM
grampa_stang
You can clear the code using the SCT Xcal or disconnect the battery for 15 mins. If it keeps coming back..it's off to the dealer.
Old Sep 1, 2008 | 12:19 PM
rford426's Avatar
rford426
hmmmm ok thanks alot gramps
