Power Window Problem
Old Aug 31, 2008 | 08:47 PM
Goldenpony's Avatar
Goldenpony
Default Power Window Problem
I am having a worsening problem with the passenger side door window in my '06 GT 'vert. It seems to loose it's memory. Sometimes I will find the window has lowered it self. When I try to raise it, when it gets to the top, it just goes back down, by it self. I go through the reset procedure and after 1 or 2 resets, it seems to work OK. The problem seems to be getting worse. Any ideas?
Old Aug 31, 2008 | 08:54 PM
suttanstyle's Avatar
suttanstyle
I believe the power window motor is covered under warranty.
I’d call your local Ford dealership and schedule a service appointment.
Old Aug 31, 2008 | 09:19 PM
princessturtle's Avatar
princessturtle
i would see about replacing ur battery and possibly seeing if ur alternator had it's diods go bad in it. my did that. i replaced the battery and it helped for a while. i took it into ford later on and they replaced the alternator. haven't had the problem since then.
Old Aug 31, 2008 | 10:14 PM
Misbehavin's Avatar
Misbehavin
That's the direction I'd consider. Problems with the windows are often a symptom of what she described.
NorthAmericanTuning
Nov 9, 2016 11:45 AM
NorthAmericanTuning
Mar 18, 2016 11:21 AM
JonnyBlazeGT
Nov 3, 2015 01:10 AM
movielover40
Aug 27, 2015 10:13 PM
HorsePower99
Aug 26, 2015 11:29 PM
