Need help removing Rust on Muffler tips
Old Sep 4, 2008 | 01:45 PM
buffguy's Avatar
buffguy
Default Need help removing Rust on Muffler tips
I have tried turtle wax chrome polish/rush remover. I have even used the green pad from the kitchen. The rust does not come off. My current exhaust is the frpp stingers. Would CLR remove the rust or will that remove my chrome also?
Old Sep 4, 2008 | 02:50 PM
oh6vee6's Avatar
oh6vee6
I use NeverDull on my tips. Should help with your rust.
Old Sep 4, 2008 | 03:04 PM
suoperdave84's Avatar
suoperdave84
I know this sounds crazy, but I saw on Mythbusters they used balled-up aluminum foil and Coca-Cola. just wet the foil and polish the tips. It's worth a shot.
Old Sep 4, 2008 | 03:30 PM
MELLOWYELLOW06's Avatar
MELLOWYELLOW06
Ask this question on www.meguiarsonline.com
buffguy's Avatar
buffguy
holy crap that is weird. I will try it later.
Old Sep 4, 2008 | 04:42 PM
SaddleUp's Avatar
SaddleUp
My exhausts seem to have this blackish-colored residue on the outer circles....is this what you are talking about? Mine doesn't seem to want to come off no matter what I do.....I thought it had something to do with my cai/tune and using higher octane gas....is this true?
Old Sep 4, 2008 | 04:53 PM
deekum1627's Avatar
deekum1627
try steel wool the 0 grade tho so it wont scratch it will def work
Old Sep 4, 2008 | 05:07 PM
99flhr's Avatar
99flhr
Simichrome metal polish OR SOS soap pads
Old Sep 4, 2008 | 05:10 PM
howarmat's Avatar
howarmat
s197 Junkie
My stingers dont have rust on them really, they have the black residue like saddle has stated. Usually that is a sign you are running rich for the a/f ratio. Its unburnt fuel. Neverdull helps but you need to use it regularly so it doesnt build up to bad.
Old Sep 4, 2008 | 09:14 PM
CorruptedDemon60's Avatar
CorruptedDemon60
that mythbusters thing is with Tin foil not aluminum foil. just pour coke on the tip and rub with the tin foil and it takes it off. It worked on my brothers chrome bumpers.
