Spark Plug removal
Old Sep 6, 2008 | 05:56 AM
loots06's Avatar
loots06
Default Spark Plug removal
I've heard horror stories about people removing the stock plugs and having them break and fall into the engine. I'll be installing new plugs, Autolite HTO's, with my S/C. Are there anyother tips on removing the stock spark plugs other than just being careful. Your feedback is greatly appreciated.
Old Sep 6, 2008 | 06:05 AM
GrayPony's Avatar
GrayPony
There is a TSB on the proper procedure
Old Sep 7, 2008 | 12:20 AM
loots06's Avatar
loots06
TSB? anyone..forgive me.
Old Sep 7, 2008 | 05:50 AM
cavediver's Avatar
cavediver
FORD: 2004-2008 F-150
2005-2008 Expedition, F-Super Duty
LINCOLN: 2005-2008 Navigator
2006-2008 Mark LT
2005-2007 4.6 Mustang GT
This article supersedes TSB 06-15-2 to update Vehicle Applications, Service Procedure and Part List.
ISSUE:
Some 2004-2008 F-150, 2006-2008 Mark LT, 2005-2008 F-Super Duty, Expedition, and Navigator vehicles built with a 5.4L 3-V engine and has a engine built date before 10/9/2007, may experience difficulty with spark plug removal. This may cause damage to the spark plug and leave part of the spark plug in the cylinder head.
ACTION:
Refer to the following Service Procedure for techniques to remove the spark plugs and extract broken spark plugs.
SERVICE PROCEDURE
The engine build date can be read on the left hand cam cover information sticker.
To remove spark plugs without damage, it is necessary to adhere exactly to this procedure before removal is attempted.
CAUTION: DO NOT REMOVE PLUGS WHEN THE ENGINE IS WARM OR HOT. THE ENGINE MUST BE AT ROOM TEMPERATURE WHEN PERFORMING SPARK PLUG SERVICE. REMOVING THE SPARK PLUGS FROM A WARM/HOT ENGINE INCREASES THE CHANCE THE THREADS COULD BE DAMAGED.
Spark Plug Removal Procedure
Remove the coil-on-plug assemblies and thoroughly blow out the spark plug wells and surrounding valve cover area with compressed air.
Back out the spark plugs no more than 1/8 to 1/4 of a turn. Using Motorcraft® Carburetor Tune-Up Cleaner, fill the spark plug well just above where the jamb nut hex sits (1/2 - 3/4 teaspoon). A minimum period of 15 minutes of soak time is required. The cleaner will wick down to the ground electrode shield and soften the carbon deposits in this time. DO NOT WORK the spark plug back and forth at this point.
NOTE: COMPLETELY REVIEW THE PRODUCT LABEL FOR THE MOTORCRAFT CARBURETOR TUNE-UP CLEANER PRODUCT - USE AT ROOM TEMPERATURE AND SHAKE WELL.
CAUTION: EXCESSIVE MOTORCRAFT® CARBURETOR TUNE-UP CLEANER, OR REPEATING THE PROCESS SEVERAL TIMES WITH TOO MUCH CLEANER FLUID, COULD INTRODUCE ENOUGH LIQUID VOLUME TO HYDRO-LOCK THE ENGINE.
CAUTION: DO NOT USE AIR OR POWER TOOLS FOR SPARK PLUG REMOVAL. SPARK PLUGS MUST ONLY BE REMOVED WITH HAND TOOLS.
Slowly turn the spark plug out. Some screeching and high effort may be noticed, but not in every case. The expected removal torque is about 33 lb-ft (45 N-m), but should decrease on the way out. If it is higher, try turning the spark plug back in a half turn, then back out again. If the turning torque still seems high, repeat the back and forth rotation along with introducing additional Motorcraft® Carburetor Tune-Up Cleaner to reduce turning effort.
Separated/Broken Spark Plug Removal
If the spark plug does come apart even after following the Spark Plug Removal Procedure, it will break in one of two modes:
Mode 1: The ground electrode shield is left behind as an empty shell. (Figure 1)
Figure 1 - Article 08-1-9
Mode 2: The porcelain center and ground electrode shield is left behind and only the upper jamb nut comes out, or the porcelain breaks with a section remaining in the ground electrode shield and only the upper jamb nut and a section of porcelain comes out. In this case additional soaking with Motorcraft® Carburetor Tune-Up Cleaner is required to dissolve carbon deposits. Long-reach nose pliers should be used to grasp and remove the porcelain center from the ground electrode shield. (Figure 2)
Figure 2 - Article 08-1-9
Once there is only an empty ground electrode shield left in the cylinder head, perform the following steps to remove the shield using Rotunda Special Service Tool 303-1203. (Figure 3)
Figure 3 - Article 08-1-9
NOTE: THIS TOOL IS ONLY DESIGNED TO WORK WITH AN EMPTY GROUND ELECTRODE SHIELD. IF THE SPARK PLUG CAME APART AS DESCRIBED IN MODE 2, THE PORCELAIN CENTER MUST BE REMOVED PRIOR TO FOLLOWING THESE STEPS. IF ATTEMPTS TO REMOVE THE PORCELAIN CENTER ARE UNSUCCESSFUL, CONTACT THE TECHNICAL SERVICE HOTLINE FOR ADDITIONAL REPAIR DIRECTION.
The combustion chamber must be protected from contamination during the extraction process by using a modified protective cap as a stopper-type plug. This is because the remaining ground electrode shield will be thread-tapped, so the cap is needed to prevent thread chips from falling into the cylinder bore. Cut a vacuum cap to a 3/8 inch (10 mm) length for each ground electrode shield that needs to be removed.
Install the modified cap with a long drill bit or suitable wire, sized for the internal diameter of the cap. The rubber cap should bottom-out on the electrode strap of the ground electrode shield once installed. (Figure 4)
Figure 4 - Article 08-1-9
Thread-tap the ground electrode shield using a 9.0 x 1.0 mm plug tap (tap profile is about 3-4 reduced diameter threads on the tip end).
Coat the end of the tap with general purpose grease. (Figure 5)
Figure 5 - Article 08-1-9
Turn the tap about 3 to 4 turns into the ground electrode shield once the tap begins to cut. As the shield is tapped, for every 1/2 turn, the tap should be backed up 1/8 turn to break chips and prevent any cut material from coiling-up and laying in the spark plug well. All of the thread chips will embed in the grease pack or drop inside the vacuum cap when following this procedure. A suitably sized tap wrench of about 7-9 inches in handle length will aid in reaching down the well. If not available, use an 8 point socket with a ratchet and drive extension. Keep the shank aligned with the axis of the spark plug bore cavity to prevent possible thread bore damage. Use care not to damage any spark plug threads on the way in.
CAUTION: DO NOT ATTEMPT TO REMOVE THE GROUND ELECTRODE SHIELD WITH THE TAP AND WRENCH. THE TAP MAY BREAK IF THIS IS ATTEMPTED.
Carefully back out the tap while maintaining the residual grease coat on the tap which contains some chips. Take care not to touch the sides of the spark plug well bore during removal.
Once the ground electrode shield is tapped, thread Rotunda Special Service Tool 303-1203 into the ground electrode shield to extract it from the spark plug well and encapsulate any remaining chips from falling into the combustion chamber.
NOTE: SEE FIGURE 6 FOR DETAILS OF THE TOOL AS INSTALLED IN THE HEAD.
Figure 6 - Article 08-1-9
Install the stepped end of the tool pilot bushing into the spark plug well ensuring it bottoms out.
Screw the center shank into the ground electrode shield. Do not over tighten the shank, to prevent thread stripping.
Install the nylon washer and jack nut until finger tight.
Turn the jack nut with a socket and 3/8 inch drive ratchet until the ground electrode is freed from the cavity and withdraw the tool assembly. Several turns of the nut are required. Upon removal, any remaining chips not caught earlier by the tap grease will be captured by the rubber plug sitting at the bottom of the ground electrode shield.
NOTE: ONCE THE SPARK PLUGS HAVE ALL BEEN REMOVED, NEW PLUGS SHOULD BE INSTALLED USING A FILM COATING OF MOTORCRAFT® HIGH TEMPERATURE NICKEL ANTI-SEIZE LUBRICANT ON THE GROUND ELECTRODE SHIELD OF THE NEW SPARK PLUGS. (FIGURE 7) DO NOT COAT THE ELECTRODE STRAP OR THE PLUG WILL MISFIRE. THE NEW SPARK PLUGS SHOULD BE INSTALLED WITH NO LUBRICANT ON THE THREADS AND TORQUED TO SPECIFICATION, 25 LB-FT (34 N-m).
Figure 7 - Article 08-1-9
PART NUMBER PART NAME
PM-3 Motorcraft® Carburetor Tune-Up Cleaner
XL-2 Motorcraft® High Temperature Nickel Anti-Seize Lubricant
382444-S Protective Cap
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage And Emissions Warranty Coverage
IMPORTANT: Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
MT080109 Claim Labor As Actual Time Actual Time
DEALER CODING
BASIC PART NO. CONDITION CODE
12405 01
Old Sep 7, 2008 | 06:27 AM
loots06's Avatar
loots06
Thanks.
Old Sep 7, 2008 | 06:37 AM
05 Mustang's Avatar
05 Mustang
just take your time
Old Sep 7, 2008 | 10:15 AM
ym42's Avatar
ym42
Good luck, please update on the results!!!
Old Sep 8, 2008 | 07:27 PM
mxg30's Avatar
mxg30
Im not the ost savy on these forums but somewhere I replied to a post not long ago and here is the short:
I changed my plugs at over 50K to prove a point that the majority of the plug problems were with the early 3V in the F-150's and only a few have had this trouble with a Mustang and these were early S197's.
This says to me that it was mostlikely a bad batch of plugs vs. the overall design.
Follow the TSB and take your time. DO NOT use too much carb cleaner or other lubricant to free up the plugs (it doesn't take much)'
Good Luck, It's no big deal.
Old Sep 8, 2008 | 07:57 PM
Mustangmaster's Avatar
Mustangmaster
What year model is your car?
Old Sep 8, 2008 | 08:30 PM
PSUSkier's Avatar
PSUSkier
This is the first time I actually took a moment to read the TSB. I went down to check the cam cover and my manufacture date appears to be 10/27/07. Bullet dodged: check.
