Anyone else have problems with their taillights?
Just curious, I've owned my 2006 V6 for 2 years now and came out to my car to find that my rear turn signal is burned out AGAIN! After this time, I'll have replaced my rear turn signals 3 times. Twice on one side, and once on the other. I've never seen a car go through bulbs like this! Anyone noticing this problem?
are the bulbs you are replacing an aftermarket brand or from motorcraft? if they are aftermarket, they might me poorly made (doesn't mean a motorcraft bulb can't be bad either). the amount of times it has happened to you, though, seems like it might be shorting out or overloading like pascal mentioned.
I've replaced my passenger side bulb once. It was a couple months after having my sequentials installed, I doubt that had anything to do with it though.
It's an easy fix unless you have the shaker box in the trunk. It is a pain to get the one nut off without dropping it because the speakers don't allow much room to get your hand in there.
