upper control arm, what good is it
any of you guys have one of these adjustible ones , who makes the best one ,and what does it do for you , or why did you purchase one for your car.
Hello, an adjustable upper control arm is used to correct the pinion angle. We offer two different styles, bushing and spherical bearing. The factory upper has a very soft bushing in it and replacing it with a arm that has a higher durometer bushing will also increase the way that part performs. Use an angle finder on the rear of the drive shaft and on the rear end itself. We suggest a pinion angle of -2 to -3 degrees. If you want to give me a call i can explain the way to take the measurements. If you lower your vehicle your pinion angle is going to be off.
what problems will my eibach pro kit cause, being you say the pinion angle is off, is it worth correcting and will the bmr cause more vibration or rear end noise travel.
Legion5 that is hard to believe 15-20 hp but if that is true can anyone else chime in on this , i will be getting a adj uca if this is correct. bmr guy what do you think?
