Wheel Problems - Car Vibrating / Shaking
Old Sep 19, 2008 | 10:02 AM
grampa_stang's Avatar
grampa_stang
Did you guys remove the little retainer clips from the stud that are put on from the factory? They're used to hold the rotors in place during assembly. It's VERY common for the tire guys to leave those on. That WILL cause the problem you're having. This issue has come up on here several times, and 99% of the time, those clips were the problem.
Old Sep 19, 2008 | 10:27 AM
ink003's Avatar
ink003
he mentioned that the tire place removed four of the clips when they installed his 20"s. and although the hubcentric rings may not solve the problem, i still think they're worth a shot. i got mine from the distributors i bought my am wheels from. try calling cruizin concepts, or maybe even a place like tirerack, and see if they'll send you some.
Old Sep 19, 2008 | 10:38 AM
grampa_stang
So much for that speed reading class I took...what a jip.
Old Sep 19, 2008 | 10:56 AM
05 Mustang's Avatar
05 Mustang
Originally Posted by DJStile
So where can I get these hubcentric rings from? And are there specific sizes to get or just like ones for a 20" wheel?
most aftermarket wheel and tire shops can measure for the correct hub rings to fit your needs and have them within a week, if not less. I would just call around and ask.
they will be specific for each "wheel" (ie: the hub rings that are used on my rims may be wider than the ones that are needed for yours)
Old Sep 19, 2008 | 12:51 PM
yellowstang05's Avatar
yellowstang05
you might still be out of alignment
Old Sep 19, 2008 | 02:16 PM
DJStile's Avatar
DJStile
Well the tire guy RE-balanced all four wheels and test drove the car before calling me to pick it up and so far everything is perfect, on the way to work at least. He told me there was also a large nail in one of the tires on the side facing the car (so I would be unable to see it). I don't know how the nail could affect the driving so much, but whatever the case, everything is working now!
Old Sep 19, 2008 | 03:08 PM
157dB's Avatar
157dB
Cut & Paste Expert
Ditch your current wheel tire guy for
someone who knows what they are doing.
That guy is letting 20s out of his shop uncentered?
Idiot.
Old Sep 19, 2008 | 03:23 PM
DJStile's Avatar
DJStile
Idiot.
What do you mean by uncentered? I asked the guy about the rings and he said they would only be necessary if I were using wheels not made for this car and according to CruizinConcepts, these wheels were produced SPECIFICALLY for the 2005-2008 Mustang.
Old Sep 19, 2008 | 03:29 PM
99flhr's Avatar
99flhr
The O.P.`s vehicle may or may not be in alignment, however, contrary to popular belief that is rarely the cause of vibration. One is geometry, the other rotating mass.
Old Sep 20, 2008 | 12:49 PM
157dB's Avatar
157dB
Cut & Paste Expert
Ask the qualified tire dude if he tightened up your lug nuts in a
star pattern or simple ran them on with a 250 Ft Lb impact wrench
one at a time.
