Need help guys... problem with Xcal2
Old Sep 20, 2008 | 09:23 AM
Johnboy7701's Avatar
Johnboy7701
Default Need help guys... problem with Xcal2
Hey guys well I was installing my 93 race tune and followed the steps and half way through putting it into my ecu the xcal2 went blank and now I cant start the car. It didnt finish installing the tune and erased the other one in it... anyone know how to fix it... thanks guys
p.s. I searched and found one thread stating to check fuses so gonna go check and sorry for not using the search first kinda spur of the moment but if any other suggestions throw them my way...
Old Sep 20, 2008 | 10:17 AM
Johnboy7701
Well found out it was a blown fuse sorry for the thread but just in case it happens to someone else it was fuse number 8 on the passenger side footwell 10amp fuse... I guess the search button does work...
Old Sep 20, 2008 | 10:38 AM
hammeron's Avatar
hammeron
glad it was something you could fix
Old Sep 20, 2008 | 10:48 AM
Johnboy7701
yeah me too, didnt want to spend 100+ taking it to the dealer...
Old Sep 20, 2008 | 01:39 PM
grampa_stang's Avatar
grampa_stang
BTW: It's always fuse #8. This fix should be made permanent...inside of a sticky so somewhere.
Old Sep 20, 2008 | 04:58 PM
157dB's Avatar
157dB
Cut & Paste Expert
Fuse #8 is for the OBDII port power.
Just to make it searchable.
This info and more is also in a little unknown
publication known as the OWNERS MANUAL.
Old Sep 20, 2008 | 05:29 PM
wingman75's Avatar
wingman75
Thanks for the 07 manual. I had the 05 version but it might be the same I guess.
Old Sep 20, 2008 | 09:24 PM
JimC's Avatar
Super Moderator
Do you have any aftermarket electrical components on your car? I found that if I leave my Sirius receiver powered up that it will blow the fuse everytime I plug in my Xcal. If I turn the receiver off, then no problems. It only took 5 fuses to figure it out!
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
