Front Jacking/Jack Stand points
Old Sep 21, 2008 | 02:26 PM
volcomchester18's Avatar
volcomchester18
^^^+1, wood is your friend Helps alot especially when you have to lift or support an engine without damaging it.
Old Sep 21, 2008 | 03:46 PM
hammeron's Avatar
hammeron
if you mean under the oil pan, i've also
heard you can use a telephone book and
because if deforms a little, it may not put
a crease in the pan....
i haven't tried it personally, but it sounds
reasonable....
Old Sep 21, 2008 | 05:07 PM
Twiztga's Avatar
Twiztga
Where Pascal shows is where I put my jackstands, I just couldn't get my floorjack back that far and actually crank it to lift w/o hitting the side skirt. So I rolled up on the ramps, then slid the jack in and cranked it about 3" more and put the jack stands there. I guess in the future I could use that little crease where the side skirt is that they say you should use with the stock jack for changing a tire. I used 3 pieces of rubber taped on to avoid metal to metal damage on anything.
Finally got the Pypes O/R H in and it sounds good! Its loud and lopes quite a bit low but a t WOT its like a stock car I'm hoping some of the hollow metal sound goes away as they break in some.
Old Sep 21, 2008 | 06:20 PM
shanec's Avatar
shanec
The picture on the right...I take it the frame-shaped place that looks double-layered is safe for jack stands?
Old Sep 21, 2008 | 06:26 PM
Twiztga's Avatar
Twiztga
If you look at page one, the 3rd part down very close to the mid is that.
Old Sep 21, 2008 | 09:37 PM
pascal's Avatar
pascal
S197 Section Modder-ator
reasonable....
Hammer... Do you plan to keep your motor mounts for long?
I wouldn't advise jacking up from under the pan, man.
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
PB Pod
Forum Issues and Feedback
Sep 17, 2015 08:32 PM
Sparks_88
Sep 8, 2015 01:06 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
