Check engine light...huh
Old Sep 23, 2008 | 05:20 PM
matt07GT's Avatar
matt07GT
Default Check engine light...huh
Ok....for some reason my check engine light popped on today when I was driving home from work. The car is running fine...i checked to see if the gas cap was tight...it was....any clue at all? I know its a shot in the dark...but I really do not feel like taking off the cai/tune and bringing it back to a dealer. Should I just redo the tune? Thanks
Matt
Old Sep 23, 2008 | 05:24 PM
americaniron's Avatar
americaniron
Hook up your tuner, and read what the code is. Then clear it and see if it pops up again. Probably nothing, but keep tabs on it
Old Sep 23, 2008 | 05:26 PM
guydon's Avatar
guydon
/\ +1
Old Sep 23, 2008 | 05:43 PM
matt07GT's Avatar
matt07GT
So just plug the tuner in and it will tell me a code????...how do I clear it?
Old Sep 23, 2008 | 05:56 PM
matt07GT's Avatar
matt07GT
am I looking for the PCM strategy?
Old Sep 23, 2008 | 06:24 PM
avengence's Avatar
avengence
You are looking for trouble codes I believe is what it calls them.
Old Sep 23, 2008 | 06:28 PM
matt07GT's Avatar
matt07GT
Not to sound like a complete newb....but where would I even find the "trouble codes"
Old Sep 23, 2008 | 06:46 PM
matt07GT's Avatar
matt07GT
ok I got it....error code po133 02 s cir slow response
caused by exhaust leaks, maf sensor, inlet leaks, incorrect fueling, or short/open wiring
What now? I guess I need to do a full look over on the exhaust, inlet tube, check the maf sensor....and fueling should not be an issue because I have been using the same gas for awhile.
So with all of that being said.......can I just erase the code and see if it comes back?
Old Sep 23, 2008 | 06:51 PM
moosestang's Avatar
moosestang
You still have your cats?
Old Sep 23, 2008 | 06:52 PM
surf808's Avatar
surf808
Do you have long tube headers?
