spark plug change without tsb
Old Sep 30, 2008 | 08:18 AM
btorlv's Avatar
btorlv
Default spark plug change without tsb
Has any one changed there plugs with out using the soaking fluid? I have a 06 with 14000 and just wanted to put the champions in. I was afarid the fluid would foul the new plugs iwa going to use the rest of the tsb.
Old Sep 30, 2008 | 10:06 AM
06elnr's Avatar
06elnr
I did mine with no fluid, 06 at 22000 miles with no problems, once you break them loose just be careful if they get real hard to turn use the fluid. i just turned slow and they got easier and easier...
Old Sep 30, 2008 | 10:18 AM
marcuskeeler's Avatar
marcuskeeler
I must admit, using the fluid is essential if the plugs are stuck due to fouling, but even after airlining around the plugs beforehand, it's going to wash all sorts of crud into the chamber, onto the pistons and down the walls, possibly getting jammed between piston & wall causing small scratching.
My first move would be to carefully try the plugs dry instead of arbitrarily swamping the plug with fluid.
Old Sep 30, 2008 | 02:57 PM
Lifter583's Avatar
Lifter583
My 06 GT had 11500 when I changed them this spring. I soaked them and they were STILL A BIT** to break loose. Once they did pop loose, (Used Sea-Foam Deep Creep), the fluid softened the carbon instantly. I had to go over 50 lbs to get them loose. I personally would follow the TSB. I run Champions with anti-sieze. No problems now. It was a damn stressful time though.
Old Sep 30, 2008 | 11:16 PM
doode's Avatar
doode
without a doubt, use some sort of penetrating oil
i had to use 65 ft pounds to break my plugs loose
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
Emblazoned
Sep 3, 2015 10:45 PM
