CLUTCH SQUEAKING
Old Oct 6, 2008 | 12:21 AM
AmericanMuscle4.6GT's Avatar
AmericanMuscle4.6GT
Default CLUTCH SQUEAKING
god, my clutch is squeaking like a mother****er. when i put it in, this embarassing squeak.............what would you recommend doing about it?
Old Oct 6, 2008 | 05:32 AM
cavediver's Avatar
cavediver
If the noise is a constant 'squeal' while you have the clutch pushed in, and then goes away when you let it out, it is more than likely a bad throw out bearing. Only choice is to replace it. If you are mechanically inclined and work on cars it's not a really difficult job. If it was me, I would also install a new clutch and pressure plate while it was out.
Old Oct 6, 2008 | 07:16 AM
CKurello's Avatar
CKurello
Or is it when your pushing the clutch in at a reasonable speed (not jamming it down) that is squeaks like it's not been oiled? I'm having the same problem. I think it's from humidity buildup inside the car. I'm going to put some silicon spray or W-D40 on it
Old Oct 6, 2008 | 02:26 PM
AmericanMuscle4.6GT
as the clutch is moving, in or out, it makes a squeaking sound. once its on the floor/released its quiet. i'll take a video.
Old Oct 6, 2008 | 03:05 PM
Nuke's Avatar
Nuke
If it's only when you press in the clutch AND it's coming from inside the vehicle, try WD-40 like CKurello suggested. Get a flashlight and get under the steering column and figure out where that bad boy is coming from.
Riptide's Avatar
Riptide
Mine squeaks when I operate the pedal as well on occasion. Never bothered to do anything about it since it's intermittent.
Old Oct 6, 2008 | 03:33 PM
AmericanMuscle4.6GT
it never used to be this bad but now its just distracting.
also i have this ****ing rattle i can't seem to find. coming from behind me. driving me ****ing NUTS
Old Oct 6, 2008 | 03:36 PM
Riptide's Avatar
Riptide
My car has a sound like metal tapping on glass that is coming from the rear of the car. Been there since I bought it. We can't fix it. Ford's body shop tried to fix it. Noone can figure out exactly where it is but it sounds like it's from the rear parcel shelf area or up in that rear passenger side panel near the defroster hookup.
My roomate's 07 just started to make this noise as well.
These cars make noises. Rattles. Thumps. It's only gonna get worse as they get older.
Old Oct 6, 2008 | 04:57 PM
AmericanMuscle4.6GT
this has been mostly since i got it back from the bodyshop when i got rear-ended. **** i can't figure out what it is and its just unbelievably annoying.
Old Oct 6, 2008 | 05:39 PM
Lifter583's Avatar
Lifter583
I shot the clutch pivot point with WD-40, no more squeek
