rusty rotor fix
Old Oct 11, 2008 | 11:35 AM
Greg06GT's Avatar
Greg06GT
Default rusty rotor fix
my 06 Gt has parts of the brake and rotors rusty. not the actual braking surface but at the top of the 2 rotors and at the hub. Not a big problem but i dont like the way it looks. any suggestions on how i could go about painting that. high temp paint obviously, but anything else? thanks
Old Oct 11, 2008 | 12:54 PM
kingsofcrunk's Avatar
kingsofcrunk
mine did the same thing. been putting off high temp paint for a while now...I know their is some sort of spray that someone asked about a while back for their drive shaft. Maybe someone will post it up.
Old Oct 11, 2008 | 12:55 PM
jahudso2's Avatar
jahudso2
There is a G2 caliper painting kit you can use, since I assume its your calipers rusting. You can even get it in a color that matches your exterior paint.
Old Oct 11, 2008 | 01:00 PM
Johnboy7701's Avatar
Johnboy7701
I think he is talking about the top of the rotor where it rusts... I guess you could finesse some caliper paint on the rotor up there but might take a while...
Old Oct 11, 2008 | 01:25 PM
cobra443's Avatar
cobra443
I am planning to take care of the same issue either sunday or monday. I am using the G2 caliper paint, matched to my exterior color for the calipers. Also I will be fixing the rusty rotor porblem as well. I will be using a light gray color on the rotors so it wont stick out so much. I will make a thread on it.
Old Oct 11, 2008 | 01:38 PM
deekum1627's Avatar
deekum1627
every rotor does this you think the would make then so they dont
Old Oct 11, 2008 | 02:00 PM
cobra443's Avatar
cobra443
Yeah you would think. BUT that would cost them more money.... Thats why it will not happen.
Old Oct 11, 2008 | 03:10 PM
0NF1R's Avatar
0NF1R
this is what he is talking about (pic of mine, they do it too)
the inside and outside edges of the rotor that the brake pads do not touch is covered in rust cause by contact with rain or faucet water....im really not sure of a guaranteed way to fix this, however, some rotors are sold with a type of zinc coating that covers the entire rotor...when you apply the brakes, the pads will scrape the zinc coating away from the contact area but the zinc coating on the edges will stay intact protecting it from water and rust....
Old Oct 11, 2008 | 04:56 PM
americaniron's Avatar
americaniron
I sprayed mine with duplicolor high temp grey primer almost two years ago, and they have held perfectly so far.
Old Oct 12, 2008 | 09:26 AM
Greg06GT's Avatar
Greg06GT
Ya please make a thread and post some pics.
anyone who has applied paint please post pics.
