cervinis lower side scoops installation
Old Oct 11, 2008 | 03:30 PM
tungsten07's Avatar
tungsten07
Default cervinis lower side scoops installation
hey I just picked up a pair of cervinis lower side scoops used off ebay (113 bucks already painted my color!). Anybody have any tips for installing them. It looks like I'm just going to get one quick shot at it to make them align perfectly. Thanks.
Old Oct 11, 2008 | 04:10 PM
loaded6shooter's Avatar
loaded6shooter
just pla with them with out the adhesive exposed just so you can get a feel of where they should sit, the bottom part kindof fits in the contour so that what i based mine off of. its no biggie
Old Oct 11, 2008 | 04:50 PM
americaniron's Avatar
americaniron
I just played around with setting them against the side, untill I was happy with how they would be placed. Then I peeled off the back and slapped them on.
Old Oct 11, 2008 | 05:32 PM
157dB's Avatar
157dB
Cut & Paste Expert
Lay them down against any contour first then finish applying them.
Maybe pull the protective strip off just a little leaving the end hanging
out. Place the bottoms against the body line with the peeled tape there. They should kinda stick there with the minimal amounts
of exposed 3M adhesive. Step back and eye them while there is
still a better chance of repositioning one or both before 100% of
the adhesive is exposed.
Finish by pulling out the tape strips one at a time until they are all out.
Firmly press in place and allow the adhesive to 'cure' before driving.
Also use some adhesive promoter on the scoop surface where the 3M
tape goes if the scoops dont come pre-applied with 3M tape.
Attached Thumbnails cervinis lower side scoops installation-4298adhesionpromoter.jpg
Old Oct 11, 2008 | 05:36 PM
ricekiller06's Avatar
ricekiller06
arent there suppose to be some prep steps before installing? cleaning more specifically.
i have some quarte window scoops that im waiting to put on till i finish my kit
i heard you are suppose to use de-greaser i believe on the places where the adhesive tape comes incontact with the paint? is that what you guys did???
Old Oct 11, 2008 | 05:49 PM
mxg30's Avatar
mxg30
Everyone is right. I want to add to be sure that your weather is within hi 60's or greater to insure best bond on a clean surface free of wax ect...
Old Oct 11, 2008 | 07:13 PM
loaded6shooter
i used some alcohol wipes to clean the area
Old Oct 11, 2008 | 08:30 PM
americaniron
+1 alcohol is what I've used for all my double sided tape applications.
Old Oct 11, 2008 | 08:37 PM
157dB's Avatar
157dB
Cut & Paste Expert
Isopropyl alcohol at 70% concentration is called rubbing alcohol.
Use the 90% alcohol instead of the 70% RUBBING alcohol.
There are less residues whan it evaporates.
Inky Thoughts
Old Oct 11, 2008 | 09:17 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Maybe some adhesion promoter from 3M as well after the area is cleaned with alcohol.... adhesion promoter is my friend (considering this car is held together with 3M tape)
