tail light mod
Old Oct 14, 2008 | 11:45 PM
StickShifty's Avatar
StickShifty
Default tail light mod
is there a write up to wire all three sections of your tail lights to light up when you signal or brake??
or a harness kit out there??
Old Oct 15, 2008 | 12:39 AM
swoosh's Avatar
swoosh
The meter-4-it set will give you the ability to have all three light up, but you replace one of the bulb bases on each side to do it (want to say the one closest to the faux gas cap). With that kit, you can set it to chase, sequential or standard.
With that, I'd assume most of the sequential sets will give you that ability, just don't remember my research as to if you can still keep your lights standard if you wanted.
Sequential or chase, it's still a cool and unique appearance mod if you go for it
Old Oct 15, 2008 | 01:50 AM
Burnsy's Avatar
Burnsy
if you're not scared of a little soldering get the meter-4-it kit. i love it.
oh, and chase is badass.
Old Oct 15, 2008 | 12:19 PM
Allstar's Avatar
Allstar
yeah.. chase is sex.. i might get this around christmas time..
Old Oct 15, 2008 | 01:02 PM
VictoriaRR's Avatar
VictoriaRR
This is probably a wacky idea, but what about putting a green bulb in there around Christmas time and then doing the chase mode?
Or not. That would probably be illegal, too.
Old Oct 15, 2008 | 01:05 PM
degeze's Avatar
degeze
I don't know of anything at the moment specifically for that but as others have said the (Meter-4-It) kit provides what you are looking for. Also, you will be able to switch between Sequential / Chase / and OEM mode.
I keep mine set to Chase mode. Great mod.
Old Oct 15, 2008 | 02:45 PM
Nuke's Avatar
Nuke
Probably not legal but I like how you think...
I have the sequential kit and the install was easy, about 20 minutes. It was all plug-n-play. I liked the chase kits but decided on the sequentials.
Old Oct 15, 2008 | 06:54 PM
StickShifty
thanks all. i will look into the Meter 4 it kit.
i had the web-electric kit on my 2004. i think thats what you call it
Old Oct 16, 2008 | 12:08 PM
157dB's Avatar
157dB
Cut & Paste Expert
It cant be done without purchasing an aftermarket sequential kit.
The SJB just dont like piggybacking bulbs onto other lighting circuits.
Old Oct 16, 2008 | 02:47 PM
302svt's Avatar
302svt
Here is a one. There is a better one but I can't find it right now.
http://www.nextgenmusclecars.com/for...ead.php?t=3044
