Fogs behind billet grille...DONE!!!
this may sound stupid but i'll probably never even use the fogs unless its absolutely horrible out and i need them to keep from dieing, i just love the look. Instead of seeing the ugly radiator you see stealth fogs, cleans it up i think. There is NO room whatsoever around the fogs. They are basicaly sandwhiched in there.The way the shelby grille is made i couldnt put them in the same locationg they are stock because there is a big vertical bar. So they are more of an eleanor style.
The yard sign is photoshopped in
nite shots will come later....at nite
Great job man!! Not that it really matters other than for aesthetics but in the far away shots they look a little far off to the right but then I noticed in your closeups that they look perfect - so I guess its just the stealth lights and the stripes and my eyes....
I'm pretty sure that in the stock mounts they are aimed slightly down so if you have rotated them then they maybe pointing to high up, check them at night but as you said your hardly going to use them so what does it matter...
