Steeda UDP Install
Old Oct 16, 2008 | 01:53 PM
Redsox401's Avatar
Redsox401
From: from Warwick, RI but live in Ft Walton beach, FL
Default Steeda UDP Install **DONE**
doing my own install tomorrow how hard is it anyone who has done it got any tips? i will be useing tacobills write up.
one thing im worried about is putting the belt back on the right way.
Old Oct 16, 2008 | 02:15 PM
ajaibr's Avatar
ajaibr
If you're unsure about the belt routing, take a pic with your phone. Take a few if it helps. They'll be right there with you then. The hardest part is getting the crank bolt broken loose. I've heard of people having issues with it. I got mine with just a breaker bar so I guess I'm lucky.
Old Oct 16, 2008 | 03:23 PM
trigger06's Avatar
trigger06
The crank bolt was a pain to get off for me. Couldnt get it off with just a breaker bar. I just went to a local hardware store and rented a good compressor and an impact wrench. That got it no problem.
Old Oct 16, 2008 | 04:49 PM
Redsox401's Avatar
Redsox401
got a impact wrench and breaker bar so other then the crank bolt it should be a smooth day? how long is the install?
Old Oct 16, 2008 | 05:14 PM
Va. Stang's Avatar
Va. Stang
Takes about 2 hours. You will taking your time not to scratch things up. You have to remove the fan and shroud. The belt can be lifted off and left mostly inplace during removal and install. I just lifted it over one pully to get enough slack to remove the crank pully. You might need a small puller to remove the OEM pully. I used a small 3 point puller. It worked fine for me. Don't forget some sealant on the key.!
Old Oct 16, 2008 | 06:43 PM
DarkFireGT's Avatar
DarkFireGT
Took me about 45 minutes and I've never done one before. A good impact and compressor that can exceed 130 ft/lbs is pretty much required. But otherwise it's very straight forward with TB's write-up in hand.
Old Oct 17, 2008 | 12:42 AM
Redsox401's Avatar
Redsox401
cool thanks guys
Old Oct 17, 2008 | 12:44 AM
deekum1627's Avatar
deekum1627
good luck man let us know how you make out
Old Oct 17, 2008 | 12:43 PM
Redsox401's Avatar
Redsox401
so easy even a caveman could do it!!!!
Sep 10, 2015 08:39 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
Sep 8, 2015 11:50 AM
Sep 2, 2015 08:40 PM
