Super Mustangs
Old Oct 21, 2008 | 03:41 PM
explict's Avatar
explict
Default Super Mustangs
I've noticed there are many specialty Mustangs out there and I just wanted to put up a comparison of most of them. So here they are, please let me know if I have missed any, or if I have made any mistakes. Just so you know I am taking the most potent of each company to compare. I made this list up about a year ago, so some things might be wrong!!
GT500
Hp-TQ: 500
Engine: Built Triton 5.4L with Ford GT 4 Valve heads CR: 8.4:1
Tranny: TR6060 6 speed
Quarter mile:
Weight: 3920lbs
# of unts: As many as we can buy.
MSRP:
Comes with:
-GT500 Body Kit and looks package
SUSPENSION:
-In the Front, coil-over MacPherson struts
-Reverse “L” lower control arms made of lightweight I-section steel.
-In the rear, three-link live axle with coil springs
-Panhard rod
-Outboard shocks
-Stabilizer bar.
BRAKES:
-Brembo four-piston calipers
-Vented 14-inch discs.
ENGINE - DRIVETRAIN:
-Roots-type 8.5psi Eaton supercharger Water to air Intercooler
-Dual-bore electronic throttle body borrowed from Ford’s 6.8-liter V-10 truck engine program
-High-capacity aluminum radiator
-Loop-style power-steering cooler
-Oil-to-water stacked-dish engine oil cooler.
http://www.svt.ford.com/
GT-H
HP-TQ: 325-335
Engine: Stock 4.6
Tranny: Stock
Quarter mile:
Weight: Unknown
# of units: 500
MSRP: Not for sale, rent only.
Comes with:
-GT-H Body Kit and looks package.
SUSPENSION:
-new shocks
-shorter springs
-anti-roll bars
-strut-tower brace
-cold-air intake
-new muffler
-different engine tuning
http://www.caranddriver.com/autoshow...rtz-racer.html
Saleen S281 E
HP-TQ: 550-525
Engine: Built 4.6L 3 Valve
Tranny:Saleen Quick Ratio 6-Speed Transmission with 4.10 final drive
Quarter mile:
Weight: Unknown
# of Units: As many as we can buy.
MSRP: $75,000-$105,000
Comes with:
-Saleen Body Kit and looks package.
SUSPENSION:
-Saleen Springs
-Saleen Shocks
-Saleen Front Sway Bar
-Saleen Pivot Bushings
-Saleen Panhard Bar
BRAKES:
-15 Inch Front Brakes
-6 piston calipers
-Forged steel Saleen crankshaft
-Forged connecting rods
-Saleen forged aluminum pistons
-Saleen Camshafts
-Saleen Twin-Screw supercharger
-Powerflash
Note: There are other Saleen makes which include: H 281 Heritage, Pernelli Jones, S281 SC Coupe or Vert
http://www.saleen.com/s281_e_performance.htm
Roush Stage 3 Blackjack
HP-TQ: 430-
Engine: Stock 4.6L 3V
Tranny: Stock
Quarter mile:
Weight: Unknown
# Of Units: 100
MSRP:
Comes with:
-Roush bodykit and looks package
SUSPENSION:
-Roush wheelhop reduction kit
-ROUSH Front Struts
-Rear Shocks
-Front and Rear Springs
-Front Sway Bar and Rear Sway Bar
-Pinion Snubbers)
BRAKES:
-Roush 14-Inch Two-Piece Slotted Rotors
-Roush 4-Piston Calipers
-Roush Slotted Rear Rotors
-ROUSHcharger
-Roush intake manifold
-Roush intercooler & radiator
-Roush Air induction system
-ROUSH calibrated ECM
Note: There are other Roush makes which include: Sport, Stage 1, 2 and 3, Stage 3 Blackjack, 427R, 427R Trak pak, Roadster.
http://www.roushperformance.com/must...lackjack.shtml
Steeda Q 525
HP-TQ: over 500-530
Engine: Balanced & Blue Printed 5.0L-3V SOHC V-8 CR 8.5:1
Tranny:
Quarter mile: 11.73 @ 117 mph
Weight: Unknown
# of units:
MSRP:
Comes With:
SUSPENSION:
-Sport Springs
-Tokico D-Spec Shocks & Struts
-Camber Adjusters
-Control Arm Relocation Kit
-Bumpsteer Kit
-Front Adjustable Endlink Kit
-G-Trac Brace
-Billet Strut Tower Brace
-Billet Lower Trailing Arms
-Rear Swaybar • Swaybar Chassis Link Kit • Front Swaybar
-Rear Panhard Bar • Heavy-Duty Panhard Bar Brace
-Rear Shock Tower Brace
-Steeda 3 point frame rail and torque box brace
BRAKES:
-Steeda 14” Competition Brakes
-Steeda 13” Competition Brakes
-5.0 Liter Modular
-Steeda/Magna Charger Supercharger system w/intercooler
-62 mm twin-bore throttle body
-Steeda/SCT Air Meter
-Electronic Fuel Injection w/60lb injectors
-Steeda Cold Air Kit
-Forged Crank Shaft
-Forged Connecting Rods
-Diamond Forged Pistons
-Steeda Axle Back Exhaust System
http://www.steeda.com/new_vehicles/S..._Hero_Card.pdf
Cervini C-500
Hp-TQ: 525
Engine: Stock 4.6L 3 Valve
Tranny: Stock
Quarter mile:
Weight: Unknown
MSRP:
Comes with:
-C-Series Body Kit
SUSPENSION:
-Lower Chassis Brace
-ADJ Rear lower control Arm
-ADJ Pan Hard Bar
-Lowering Spring Kit (3/4" Front, 1.25" Rear)
-Front Sway Bar Bushings
-K-Link
BRAKES:
-Wilwood 14" 2pc Cross Drilled & slotted Rotors
-6 Piston Calipers.
-High Flow Cats
-Side Exhaust
-Custom PCM Computer Recalibration
-Whipple / Ford Racing H/O System (10psi 3core Intercooler)
Not: There are other Cervinis makes which include: C300 and C350
https://www.cervinis.com/product.aspx?car=1&id=1208
Super Snake
HP-TQ: 725-
Engine: Built 5.4L
Tranny:
Quarter mile:
Weight:
# of units:
MSRP:
Comes With:
SUSPENSION:
-Ford Racing Handling Pack
-adjustable dampers
-lowering springs
-front strut tower brace
-stabilizer bars
BRAKES:
-Baer six-piston Calipers
-3.73 rear axle
Old Oct 21, 2008 | 04:13 PM
BlackSpirit's Avatar
BlackSpirit
Default ROUSH P-51A MUSTANG
ROUSH P-51A MUSTANG CONTENT:
-ROUSH 4.6L P-51 Powertrain Package (Components - Forged Aluminum Pistons w/ increased dish to lower compression ratio from 9.8 to 8.6, Forged Steel H-Beam Connecting Rods, Forged Steal Crankshaft (from six bolt to eight bolt), Premium Main and Rod Bearings, TVS2300 Supercharger, Large air-to-water intercooler, Custom Aluminum Upper and Lower Intake Manifolds for New Intercooler and S/C, Custom High Flow Fuel Injectors (52 Ib/hr), Custom Fuel Rail, Roush Throttle Body Spacer, Dual 60mm electric throttle body, Upgraded High Flow Capacity Fuel System, Upgraded Air Induction, Aluminum Flywheel, Unique ROUSH Calibrated PCM)
-Produces 510 hp/510 lb-It
-ROUSH High Performance Exhaust
-ROUSH 5-Piece Aerobody Kit (Front Fascia, Front Chin Spoiler, Rear Spoiler, Hood Scoop and Rear Quarter Window Louvers)
-ROUSH P-51 Fender, Grille and Decklid Badging
-ROUSH Front Windshield and Hood Scoop Graphics
-P-51 Embroidered Floor Mats
-ROUSH P-51 Sport Leather Seating P-51 Serialized Engine Bay Plaque
-P-51 Engine Bay Signature Plaque 1 ROUSH Short Throw Shifter w/ Retro Style Lever and Handle
-ROUSH Stage 3 Suspension (Front Struts, Rear Shocks, Front and Rear Springs, Front and Rear Sway Bars and Progressive Jounce Bumpers) ROUSH Engineered Anti-Wheel Hop Kit
-ROUSH 14// Front Brake Kit w/ 4-Piston Calipers
-Painted Rear Calipers
1 ROUSH W % It" Forged Chrome Wheels and Ultra High Performance Tires
-Locking Lug Nuts
-ROUSH P-51 Custom Graphics Limited Edition Vehicle-100 Units
Old Oct 21, 2008 | 04:20 PM
Texotic's Avatar
Texotic
most potent form? why isn't the Steeda Q650 on there?
Old Oct 21, 2008 | 04:29 PM
2005mach1's Avatar
2005mach1
so many you have not even touched the surface.
lets keep this going
Old Oct 21, 2008 | 05:03 PM
sactown's Avatar
sactown
Here is the soon to be bad boy on the block.
http://www.smslimitedusa.com/25a.html
Steve Saleen's new company
Old Oct 21, 2008 | 05:44 PM
Hufenstang's Avatar
Hufenstang
Dont forget, Saleen Sterling Silver with techno upgrade... 825hp, $101,000 ~
Old Oct 21, 2008 | 06:29 PM
explict's Avatar
explict
Ya, I made this a long time ago so there are even more coming out that I never put on that list!!
Old Oct 21, 2008 | 07:07 PM
Hufenstang's Avatar
Hufenstang
Saleen Sterling Edition with $2000 Techco "720" Updgrade,
note: the 720hp upgrade is actually more than 720 hp, 5.0 magazine tested the base saleen sterling and found it made 90 hp more than advertised. Motor trend tested the base Mustang and found it has between 15% and 16% drive train loss on the manual consistently which is much higher than a dyno operator is supposed to assign a manual car (12% is the usual number for manuals and 15%+ for autos). Anyway it's more like 825hp.
Saleen Sterling Techco:
10.116 @ 132.56 mph as tested
0-60 3.3 seconds (2.8 with drag radials)
top speed: 198+
Handeling: 1.2g skid pad
Slalom: 77mph
hp: 825
Engine: 5.0l crate engine with arguably one of the best car superchargers designed in modern times, a saleen Series IV which is a whipple core with a computer optimized aerodynamic manifold.
Cost: $99,998 + $2,000
Old Oct 21, 2008 | 08:49 PM
2005mach1's Avatar
2005mach1
Don't forget all the ford racing editions including the new cobra jet
Old Oct 21, 2008 | 09:13 PM
dlarge122878's Avatar
dlarge122878
I want one of each!
