Big 3 upgrade question...headlight dimming
Old Oct 25, 2008 | 02:19 PM
miloman's Avatar
miloman
Default Big 3 upgrade question...headlight dimming
I can't seem to find my post on this topic from a few days ago, so I lost the link you guys gave me.
Anyway, I must be blind, I have no clue where the "engine block to chassis wire" is on our cars. I see the "positive battery to alternator" and the "negative battery to chassis". Anyone got a picture? Or at least lead me in the right direction?
Old Oct 25, 2008 | 02:29 PM
lrgnation's Avatar
lrgnation
Check it out this is what I did. You don't have to remove and replace. You simply just add on another ground. Except note I made a mistake when doing mine i ran the engine ground to the battery. You want to run the engine ground to the chassis.
Engine ground to chassis.
Chassis ground to negative battery
Batt pos to alternator
Old Oct 25, 2008 | 05:10 PM
miloman's Avatar
miloman
Where is the engine ground located?
Old Oct 25, 2008 | 05:47 PM
miloman's Avatar
miloman
Ok,, I'm confused. I just read that the alternator case is usually used as the engine ground. So I need to run a cable from the battery positive to the alternator, and another cable from the alternator case to the chassis? Can the same location be used for both the negative battery ground and the engine ground?
Old Oct 27, 2008 | 07:20 PM
miloman's Avatar
miloman
bump, for some reason we only have 3 or 4 pages listed all the time.
Old Aug 27, 2009 | 09:11 PM
luckydawg003's Avatar
luckydawg003
so if I have 4 gauge wires for my amps. Do I use 4 gauge wire for my big 3 upgrade? It won't void my warranty will it?
Old Aug 27, 2009 | 09:23 PM
BruceH's Avatar
BruceH
PaulH2
20
Jan 31, 2016 09:48 AM
jrrhd73must
Oct 2, 2015 09:17 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
UrS4
Sep 30, 2015 10:13 AM
