Recommend a floor jack please
Something that costs less than $120 and can get the car high enough up that I can get jack stands under the front or rear axles without having to stick a cinder block under the jack in order to go further with it. Aluminum preferred but isn't a big deal if it's steel.
Probably needs at least 2 ton rating.
Thanks
Thanks
i would spend a little extra money and get one of these low profile jacks... im about 2 order the more expensive one cuz the profile is an inch shorter and if i drop my car that will just fit under...
http://www.northerntool.com/webapp/w...5429_200345429
http://www.nextag.com/Omega-OME29023...C593B429DE381B
What do you think of this set? My car isn't lowered if it makes a difference.
http://www.sears.com/shc/s/p_10153_1...Lift+Equipment
i picked up a craftsman 4ton low profile jack from sears on black friday last year for only a hundred bucks. best deal ive ever gotten on such great tools...black friday is coming up so if you're patient you might find something good
