New bumper on!
You have an easy color to match, so a good brand of paint should have it spot on.
Tungsten gray and Windveil blue are the only two colors that gave me fit.
The warping on the bottom is the result of stocking the bumper in a bad position...
The lower grille should align it correctly.
Good luck.
Good luck.
looks good rdsx. aside from the warp of course,but like pascal said, the grill should fix that. i do believe the gt500 grille will fit since if you look at the two, they appear to be identical. go to your local ford dealer and compare the two if you want. you should be able to order the grill from saleen since i called them and they will sell me the lower chin spoiler as well.
