Steeda UDP Question
i assume you're talking about the stud that extends out and hits the new oversized water pump pulley, no need to replace it or even take it out if you have access to a small hand held cutting device such as a dremel or die grinder. just cut it off just before the nut and it will be short enough. the nut will still come off fine if ever necessary. its what i did, very easy and the stud has yet to rust up 3 years later. or if you dont have a grinder, pull the bolt out and cut it with a hacksaw. or if you're lazy like me, take it to your local hardware store and get the same diameter bolt ,only 1/2 inch shorter.
Oct 1, 2015 09:11 PM
Sep 17, 2015 07:57 PM
Sep 16, 2015 07:53 PM
Sep 10, 2015 08:39 PM
Sep 2, 2015 08:40 PM
