Rear defrost discovery!!!
Old Nov 17, 2008 | 04:22 PM
0NF1R's Avatar
0NF1R
Default Rear defrost discovery!!!
well i never knew it before but the rear defroster on my car will not work if the a/c **** is in the defrost position....
with the rear defrost button activated, i had to turn the a/c **** to the position just above the MAX A/C position and then the rear defroster would become active....
not that it matters since this morning was only the 2nd time ive used it since i bought the car, but is this the way its always been?
Old Nov 17, 2008 | 04:31 PM
degeze's Avatar
degeze
Yes.
I guess if the temperature is so that you need to turn the A/C to max., then you will not need the defroster.
Old Nov 17, 2008 | 05:37 PM
0NF1R's Avatar
0NF1R
not ON the max position, but the position just ABOVE the MAX position on the icon that has the person sitting with an arrow pointing to its face...
Old Nov 17, 2008 | 05:38 PM
0NF1R's Avatar
0NF1R
you'd think it would work even when you have the a/c **** on warm/hot defrost but it doesnt....
Old Nov 17, 2008 | 05:45 PM
degeze's Avatar
degeze
Oh ok.
I would expect it to work anytime, I have never really noticed it only worked with certain settings.
Old Nov 17, 2008 | 06:02 PM
surf808's Avatar
surf808
I thought it was bad to turn that on if you have tint?
Old Nov 17, 2008 | 06:49 PM
o7 tungsten's Avatar
o7 tungsten
i was thinking the same thing while reading the post. i heard it was bad from someone, but it came from an unreliable source so i can't really pass info. nonetheless i still haven't used it since my tint got put on.
Old Nov 17, 2008 | 06:57 PM
tk5075's Avatar
tk5075
i wish i could remove the defroster lines that go across the window. i think that would look really clean
Old Nov 17, 2008 | 07:55 PM
Texotic's Avatar
Texotic
so that's why i couldn't tell it was working...
Old Nov 18, 2008 | 12:03 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Never knew that and hope I never have to use it!
