Front Suspension
Alright here's the deal, The front end clunks on the driver's side. Yes I have replaced the upper strut bearings, and was exptremely dissapointed to find that didn't fix it. This last time around while I was rotating the tires I decided to looks at the swaybar endlinks and mounts because other people suggested that that may be the source of the sound. Now i have a question for you all, on the upper side of the endlink, the part that attaches to the strut uses two combination wrenches to tighten. I believe I used an 8 mm for the inner stud to hold it in place and used an 18mm on the nut itself. Thing is, I feel I can't get it tight enough this way. I tried tightening the lower endlink point, the part attaching to the swaybar to get a feel for the torque and I couldn't budge it. I'm trying to figure out how you guys are tightening that endlink nut and how tight are you tightening it? I am determined to solve this noise but I can't figure it out!
I see you responded to this thread but I do know there are other TSB on the thunking that have to do with the sway bar and endlinks
https://mustangforums.com/forum/2005...07-18-2-a.html
I have to tighten my front sway bar end link, where it attaches to the strut right behind the top part of the wheel, at least once or twice a month, mostly the drivers side. Clunking noise disappears after its tightened. I don't even bother taking the wheel off, I just jack the car up until the front wheel is about to lift off the ground which usually gives enough room to fit the wrench and ratchet in there. I put the wrench on first, using the fully enclosed side, then put on a small ratchet on the end. I use the ratchet to hold, and tighten with the wrench as much as I can. When I feel like not being lazy, I'm going to take the wheel off and try some blue locktite on it and see how long that will last.
edit: You will know if that nut needs to be tightened. If it doesn't, it will be very hard to budge it since you really can't get a lot of torque on the small wrenchs that fit in the small area. When mine gets loose, I'm at least turning them 1/4 of a revolution, sometimes more.
mygt500- thanks for the response but my dealers refuse to work on my suspension because it has lowering springs on the front. Screw them. I did the strut bearings myself and had to purchase them. Forget the dealer.
AmericanSpeed- man that really really sucks. Thanks for the explanation though. We are pretty much doing the exact same thing except I'm using two combination wrenches instead of just one and a ratchet. I want to know what the dealer uses to tighten these, I know that I am not getting the proper torque.
Anyone else have anymore ideas as to how to tighten the nut effectively? I'm thinking about getting a pipe or something for leverage and putting it over the wrench. I may buy a new nut and put red loctite on it to keep it there.
I wonder how they would tighten this thing to spec, or what tools they use. It's a real pain in the @ss to tighten the thing all the time, but at least it doesn't take more than 10 minutes of my time. I see you are in Orlando too, where at do you live? Unfortunately I live in downtown and have to deal with the terrible brick roads, I'm sure they really speed up the process of loosening that nut. It's so aggrivating!
Man, I am glad I am not the only one. I replaced my lower control arms thinking it was the ball joints and it still makes the clunking noise. I was thinking of replacing the strut mounts but now I wonder. I will have to take a look at my end links and see if they are loose.
Thanks for the posts!
AmericanSpeed- I'm near UCF. Hope you're going on the cruise!
Mustangs4u- I changed my upper strut bearing thinking it would solve it and man was I so dissapointed. When I come home for winter break, I'm jsut gonna unbolt the endlink and see if the problem is solved. If it is, I have successfully nailed the problem and will most likely look into a sway bar delete or something. Maybe better endlinks. Or maybe tighten the b**** as tight as I can.
