Gauges in the right place
Old Dec 5, 2008 | 09:14 PM
Joolander's Avatar
Joolander
Lord High Protector
Default Gauges in the right place
hypothetical:
what would it take to put the tach on the right and spedo on the left?
i like the look of the stock gauges
Old Dec 6, 2008 | 01:01 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Good question.... I have no idea unless you like the GT500 gauges as they are on the way you describe
Old Dec 6, 2008 | 07:15 AM
nite's Avatar
nite
well, they're both the same size... haven't looked yet, but they likely have the same brackets in the back. I would think it'd be a simple swap. good question. someone must have done it already...
Old Dec 6, 2008 | 07:30 AM
Stkjock's Avatar
Stkjock
Retired Mod
the whole cluster is in one pod and comes out together. they are also electrical not mechanical, the service manual shows replacing the entire cluster only so I dont think its possible to change them around without replacing the assembly
Old Dec 6, 2008 | 09:11 AM
157dB's Avatar
157dB
Cut & Paste Expert
You would have to get real cozy with your Ford service department
to work on getting the module configuration right so the systems
would work together, i.e. GT500 cluster in a V6 or GT. The 'as built'
data for your stang would not work correctly loaded onto a GT500
cluster. Some tricky configuring by the ford tech would be needed.
S197 Insurment Cluster.PDF
Old Dec 6, 2008 | 09:16 AM
EagleStroker's Avatar
EagleStroker
The GT500 would be sick though, and you get a boost gauge don't you?
Old Dec 6, 2008 | 10:09 AM
cheftjpeck's Avatar
cheftjpeck
yes you do....
Old Dec 6, 2008 | 01:46 PM
Stkjock's Avatar
Stkjock
Retired Mod
near impossible from what I've read to get it to work on a GT tho, there is no factory MAP, and the PCM doesnt read aftermarket ones.
Old Dec 6, 2008 | 02:28 PM
mlcrycc's Avatar
mlcrycc
I did notice they got the positioning correct on the 2010's......
Old Dec 6, 2008 | 03:15 PM
howarmat's Avatar
howarmat
s197 Junkie
Th boost gauge will not work, many many people have looked into this. You can get the GT500 cluster for about 300-400 installed though. Just depends on how bad you want the speedo swap
