Right blinker faster than left
there are 3 bolts that poke out behind the carpet stuff inside the trunk on the side you wanna take off. I think its a 12 mm or there abouts take off the 3 nuts on those bolts and then push on the bolts while holding the taillight to pop it out. It will still be connected via wire so be careful not to stress the wires. just rotate to the left the socket of what bulb you need to replace and vwola out comes the bulb. replace it and put it back together.. ive probably pulled mine out like 10 times from painting and vht ing the rear tails... can probably do it in like 2 minutes.
3157
I would opt for the Sylvania 3157LL LongLife Bulbs
and replace them all while the housing is out.
Rear Lamp Assembly Removal
If you dont have sequentials, the inner bulb on each side is a 3057LL.
Be sure to check the auto manual to see if those are the right bulbs. The manual also tells you the step-by-step procedure on changing the bulbs. If you have any trouble changing them, just take your car to any auto parts location like Pep Boys or Jiffy Lube. It won't cost you hardly anything.
3057
I would opt for the Sylvania 3057LL LongLife Bulbs
