Plenum Cover Bolts
Old Dec 29, 2008 | 01:15 PM
Tracedaddy's Avatar
Tracedaddy
Default Plenum Cover Bolts
Does anyone have info on what the part number is for bolts that hold the front of the plenum covers on? As I understand it, 2007's had these double-ended bolts where one end bolted into the intake and the other end slipped through the holes on the front of the cover. 2005-2006 needs these special bolts. Dealers don't seem to be able to help but I've found a pic that had the separate bag of two bolts. (See attached) Trouble is I can't make out the number on the package.
Any help would be appreciated.
Old Dec 29, 2008 | 01:40 PM
Tracedaddy's Avatar
Tracedaddy
Standby. I actually was able to find something using "Search". I don't know that I've gotten that lucky before.
Problem is, dealers STILL don't know what to make of the number. They say it's a valid part but not for my engine!
https://mustangforums.com/forum/2005...num-cover.html
Old Dec 29, 2008 | 01:58 PM
xxDerek's Avatar
xxDerek
I also need the bolts, mine didn't come with them, curious to see what you turn up, I couldn't find anywhere to purchase the mounting hardware
Old Dec 29, 2008 | 03:19 PM
Devil Wolf's Avatar
Devil Wolf
the link you posted is correct, and so is the dealer when he says the mounting hardware is not for your car; the two parts are the 07 throttle body studs and nuts.
thats why the 07 doesnt need them lol.
http://www.fordracingparts.com/parts...tKeyField=9810
im sure the dealer will sell them to you.
Old Dec 29, 2008 | 03:46 PM
partsbill's Avatar
partsbill
stud # W712289-S437
nut # W520411-S437
Old Dec 29, 2008 | 04:28 PM
shoeys08dkcandygt's Avatar
shoeys08dkcandygt
are you guys taking about the screws in the front of it cover above the throttle body?
if you are doesnt the front of the cover slide in those with no nuts?
dekek with a 07 you shouldnt have to have the bolts that the guys with 05 and 06's have to have. the 07 and up ones already have them bc it is part of the appearance package that also comes with the rolled exhaust tips and hood scoop.
sorry for the questions. just tryin to clarify what you guys are really talking about.
Old Dec 29, 2008 | 04:58 PM
Tracedaddy's Avatar
Tracedaddy
I could install it without the bolts on the front. It would flop around a bit though with nothing to support it. Plus the rubber grommets on the front would look a bit odd.
I did finally get through to a dealer that would order them for me. $14. Should be in next Tuesday.
Old Dec 29, 2008 | 05:03 PM
STANMAN's Avatar
STANMAN
Hey buddy, give Midwest Auto Gear a call (they sell aftermarket plenum covers), they will hook you up, and they are right here in Pewaukee. Tell them I sent you, then they should be free, lol!!! I have done ALOT of advertising for them of course, and they are very appreciative.
Old Dec 29, 2008 | 11:08 PM
odiaz's Avatar
odiaz
Just go to your local hardware store and get two 7mm studs, washers and nuts. Remove the old bolts and insert the studs. Then, install the washers and nuts and tighten. The studs should be long enought to protrude through the nuts enough so that the plenum cover can slip over them but not so long that they look silly. When I did mine, I was able to adjust the studs to the point where they were flush with the edge of the rubber grommets on the Plenum cover. Here's a picture from when I had the plenum cover. Total cost was less then 25 cents including tax.
Old Dec 30, 2008 | 08:10 AM
Tracedaddy's Avatar
Tracedaddy
Hey back Stanman,
I didn't think of that but you're right. They could have helped me. Especially snce I shelled out the bucks to them for the matching fuel rail covers.
Too late though. I finally got someone at Hiller Ford to order them for me. Should be in Tuesday.
Thanks too to Odiaz. Looks good. On my wish list is a new intake elbow. Maybe for Father's Day.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
winner99
Oct 1, 2015 01:06 PM
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
