Predator Hiccup... need help guys...argh
Old Jun 3, 2005 | 08:35 PM
don_w's Avatar
don_w
I ♥ Acer
Default Predator Hiccup... need help guys...argh
OK... I installed the C&L CAI... no problems there. But, when I went to do the Predator tune, the were no C&L specific tunes in the Predator! Dammit...
So, now I'm trying to download the right tune and I'm not having any luck. Anyone out there got any tips?
Old Jun 3, 2005 | 08:40 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Default RE: Predator Hiccup... need help guys...argh
I've read several Mag review and what others have said on here...I would say the Xcalibrator is the better option for an 05. Dyno shop perhaps to retune your predator and get a custom program as opposed to a 'boxed' one.
Old Jun 3, 2005 | 08:43 PM
don_w's Avatar
don_w
I ♥ Acer
That's no help at the moment...
Anybody have any useful advice on downloading the tunes?
Old Jun 3, 2005 | 08:59 PM
Zeio's Avatar
Zeio
Hey Don, I haven't ordered mine yet but have you checked this page?
http://www.diablosport.com/Downloads..._tunes_C&L.php
I assume you have the PC interface kit since you bought it at RPMOutlet? If so then download the tunes listed on that page assuming everything else checks out with what you have. Then sync it up with the predator and get the tune from your PC to the predator.
Sorry if that was the page you've already had no luck with, but I bookmarked this page in the event that I need it for when I get mine ordered.
Good luck, and install those SLP powerflo's too!
Old Jun 3, 2005 | 09:04 PM
don_w's Avatar
don_w
I ♥ Acer
ORIGINAL: Zeio
Yea, I'm on that page now. Everything seems to be hooked up ok. I have the C&L tune downloaded onto the PC, but everytime I try to upload it to the Predator, I get a "waiting for connection" message for about 20 seconds, and then "Download Failed"...
Old Jun 3, 2005 | 09:26 PM
JC74's Avatar
JC74
Do you have the latest firmware update R17 installed on the predator?
Old Jun 3, 2005 | 09:30 PM
don_w's Avatar
don_w
I ♥ Acer
ORIGINAL: JC74
Actually, it's up to r21 now... and that is what is on it.
Thanks.
Old Jun 3, 2005 | 10:06 PM
281GT's Avatar
281GT
Don, make sure that your serial port is enabled in the BIOS of your computer. The data cable the Predator uses is nothing more than a plain old serial cable. Since serial cables aren't used much anymore, many computers have them disabled in the BIOS. You can check by doing the following:
In Windows XP
Right click "My Computer"
Select "Properties"
Select "hardware"
Then choose "device manager"
Look under "Ports" by clicking the little + symbol.
You should see one or two "communucations port"
These are your serial port/s
Make sure there is not a red X or a yellow exclamation mark on the port.
If there is, it has either the wrong driver, missing driver, or corrupt driver installed.
If you don't see the "communications port" at all, that means Windows can't see it at all which means it is disabled in the BIOS.
If this is the case, shut down your computer and restart and enter the BIOS setup and have a look at the "com port" and enable it.
Hope this helps.
Ex- Level 2 Microsoft Windows XP support technician.
Old Jun 3, 2005 | 10:09 PM
Higgie's Avatar
Higgie
ORIGINAL: don_w
ORIGINAL: JC74
Thanks.
I doubt that this will help much....but....
I have had several down loads of other types, that didn't prompt me to, but I needed to disable my firewall with Norton Internet Security. With it off during the down loads, all went well.
Best of luck !!!
Old Jun 3, 2005 | 10:12 PM
281GT's Avatar
281GT
He also makes a good point. Norton Internet Security will also cause problems with ANY sort of communication. I will try not to rant about all the problems this horrible product caused when I was working for Microsoft. But yes, Norton Internet Security will weark havoc with just about any sort of communications.
