Shift knobs...Lets see e'm
Old Jan 3, 2009 | 11:00 AM
  #31
VistaGT's Avatar
VistaGT
Originally Posted by deekum1627
thats cool for the auto guys which is that
TCI Ratchet Shifter
Old Jan 3, 2009 | 11:11 AM
  #32
DarkFireGT's Avatar
DarkFireGT
Black Hurst.
Old Jan 3, 2009 | 01:29 PM
  #33
odiaz's Avatar
odiaz
An Aluminum Hurst T shifter **** on the factory shifter. I used a piece of chrome nipple to cover the iron shifter .
I don't have pictures of my current set up. I am using an MGW shifter with the hurst **** now. The MGW shifter was a definite improvement.
Old Jan 3, 2009 | 04:13 PM
  #34
zporta's Avatar
zporta
i dont want a jam nut that shows...i want a type of jam nut that holds the boot tight against the ball....
Old Jan 3, 2009 | 05:52 PM
  #35
06mach1's Avatar
06mach1
heres mine...
Old Jan 3, 2009 | 05:54 PM
  #36
DarkFireGT's Avatar
DarkFireGT
In that case, all you need to buy is a large washer (with a hole just larger than the shifter and overall diameter about 1/2" wider than boot opening.) and the appropriate sized nut. If they don't have black available, pick up a small can of satin black spray paint.
Pull shift **** off.
Put jam nut on.
Pull boot up from console.
Put washer inside of boot.
Slide washer over shifter, resting on jam nut.
Screw **** on to desired position.
Tighten jam nut up to shift ****.
Re-seat shift boot.
Of course, there's other ways, but this should work fine.
Old Jan 3, 2009 | 08:08 PM
  #37
ApexStang's Avatar
ApexStang
J/C... Here's a pic of mine. My car is a GT350 Tribute, so on Ebay I found a 2" GT350 ****. The picture is actually recessed in the ****. You can't actually feel the GT350 emblem. I like it.
Old Jan 4, 2009 | 07:57 AM
  #38
degeze's Avatar
degeze
^^^Nice.
Old Jan 4, 2009 | 08:18 AM
  #39
partsbill's Avatar
partsbill
OEM Bullitt shifter boot and Hurst shifter ****, no jam nut and boot fits tight on shifter lever eliminating the grommet that came with the shifter to adapt to the stock boot.
Old Jan 4, 2009 | 09:00 AM
  #40
zporta's Avatar
zporta
i dont want a shifter leaver that shows eather
