I NEED TRACTION!!
im still N/A and with the recent mods and now with the tuner added,i cant get thru a gear with out sliding all over the place.I want to go bigger on my 20's and get a tire that has great traction, can someone recomend a good tire that will fit?I cant imagine the issues i will have when the turbo is all done.
currently running
285/30/20
245/35/20
currently running
285/30/20
245/35/20
Do some suspension work and either ditch the 20's and get some tall sticky tires, or get tall sticky tires mounted on the 20's. I'd bet that having just over 3 inches of sidewall is not helping your traction.
currently running
285/30/20
245/35/20
currently running
285/30/20
245/35/20
I understand your pain. I can light the tires with the throttle alone at 80mph. I have about burned up the stock tires and am going with the tires I put on the last car. Nittos, I think the were envos. Autocross tires. Had about 90% of a drag radial but went around corners real well. Real sticky. A little road hum at 70 though. I think I am going to order another set for this car next week so that I can get at least half throttle down in second.
yeah,but if i wanted to buy them would you return my PM? how about the plenum cover you are selling and wont even let me know if its already sold, at least return a PM so i can know what up?
not sure if you can do a 40,thats almost 4.65" sidewall,it would add about 3" over all to your tire height.
315/35/20 is a pretty big tire also,not sure if they would clear,its 12.4 inches wide and 4.34 tall. Do they make a 315/30/20?
