Goofy gauges.....
Old Jan 26, 2009 | 03:15 PM
0NF1R's Avatar
0NF1R
Default Goofy gauges.....
well its been an awesome 46k miles on the beast but finally got a malfunction....luckily its a relatively small one...too bad im 10k miles past my warranty coverage...
my oil gauge is being retarded...it started about 3 days ago....i got in the car and before cranking it up, my oil gauge read as so:
then after cranking it up, it read as so:
its like its jammed up or something....like the wire going into the back on the gauge needle has rotated a bit and now the gauge is off.....
i also checked the oil dipstick to make sure it was a malfunction, the oil level was within normal limits....
any of you gurus have a solution for this?
Old Jan 26, 2009 | 05:07 PM
Johnboy7701's Avatar
Johnboy7701
only thing I could think of would try and take the dash apart and try and diagnose it from there, maybe disconnect the wire going to it and see if it resets. I know it would be a pain in the A$$ but sometimes you gotta tinker with stuff...
Old Jan 26, 2009 | 06:52 PM
vaporstang's Avatar
vaporstang
Would disconnecting the battery reset it? Would that be the same thing as disconnecting a wire? Might be worth a try before taking the dash apart... I know doing that reset my engine light on my Escort - (which of course is not an analog gauge).
Old Jan 26, 2009 | 07:09 PM
ABQstang89's Avatar
ABQstang89
My money is on a sending unit. If you wanna take it out you can check it to see.
Old Jan 26, 2009 | 07:45 PM
one eyed willy's Avatar
one eyed willy
try disconnecting the battyer first
check the wires where the sending unit is next to the oil filter
then see if you could borrow another cluster,from someone
then buy a new sending unit,should be cheap
if none of the above works....trade it in for a gt500KR
Old Jan 26, 2009 | 08:02 PM
hammeron's Avatar
hammeron
that is a great fallback plan!
Old Jan 26, 2009 | 08:58 PM
eric6913's Avatar
eric6913
Angry
ford should have a recall on their clusters. i also have the same type of issue as well as do many other members!
Old Jan 27, 2009 | 12:18 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
Thats yet another reason why they make aftermarket gauges!.....the factory ones are not accurate and FAIL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jan 27, 2009 | 01:50 AM
07musclemustang's Avatar
07musclemustang
if all else fails you might wanna pull off the needle and reset it in the proper spot??
and buy an aftermarket guage to keep an eye on it for real. It seems to look like the needle is just to far off... kinda like it got jammed over. Just an idea. I would do the above first and then use that as a last resort
Old Jan 27, 2009 | 06:20 AM
0NF1R's Avatar
0NF1R
hmmm....ill try the battery trick but im not sure it will work....if that doesnt do the trick, ill sit on it for a bit since it not THAT important right now as long as i keep an eye on the dipstick....they dont really check your guages in shows so i guess it wont hurt me too bad.....
