Will I need an adjustable UCA
Old Jan 27, 2009 | 07:12 PM
mike_kinda's Avatar
mike_kinda
Default Will I need an adjustable UCA
Hy, I just got the aluminium spydershaft. My car is lowered 1.5 inches with the ford springs and I have bmr lca's with the relocation brackets. Do you guy's think I will need the adjustable upper to solve any vibration that might come up, or will things be ok. My car is stored till april, so I'm just trying to get ready in advance.
Thanks,
Old Jan 27, 2009 | 08:36 PM
RICVA05's Avatar
RICVA05
I would really consider getting a UCA it will make life a lot easier adjusting your pinion angle. But it can be a pain installing.
Old Jan 27, 2009 | 09:17 PM
Stkjock's Avatar
Stkjock
Retired Mod
check your pinion angle, if its at -2* or so you should be ok
but +1 to RICVA05'S comments
Old Jan 27, 2009 | 09:43 PM
mx07gt's Avatar
mx07gt
If you are lowered, you have to have adjustable
Old Jan 28, 2009 | 02:19 AM
tx_zstang's Avatar
tx_zstang
You might need it, might not like stated. Check you pinion angle to see if you need one. Even after lowering, my pinion angle was fine (although that's with using lca relocation brackets which might have moved the angle a little to where it needed to be).
FWIW, a bit of a PITA to put in, but it can be done.
cr620
Oct 3, 2022 10:18 PM
baddog671
Jul 26, 2016 01:20 PM
Thunderball
15
Nov 22, 2015 11:49 PM
UrS4
Oct 3, 2015 06:23 AM
winner99
Sep 30, 2015 07:04 PM
