Back from Service
Old Feb 11, 2009 | 05:00 PM
gnrpatience's Avatar
gnrpatience
Default Back from Service
So my car is back from Service.
I used Motorcraft 5w 40 since is the only syntethic that Motorcraft sell here in Mexico. The stealership called and said that rear brakes will last just 5000kms if i want to change them, i told them not.
Do you know if brakes like these ones will last 30 000kms ?
Im thinking on taking the pony with someone i trust to check them and then see what he said.
Old Feb 11, 2009 | 05:29 PM
owero01's Avatar
owero01
I have over 82,000 miles on mine and still have the stock pads on it. Depends on your driving habits.
Old Feb 11, 2009 | 07:29 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Damn Messicans!
I think the engines only last 20K miles or so in Mexico
Si Senior.
Old Feb 12, 2009 | 09:44 AM
gnrpatience
Originally Posted by pascal
Damn Messicans!
Si Senior.
Well mine is 30000kms and is running as new LOL.
Well this means that the stealership is lying and my rear breaks pads should be fine ?
Thanks
Old Feb 12, 2009 | 09:48 AM
gnrpatience
Wow! man 82000miles with stock pads ?
Well im a daily driver in the city and normally i got stuck on traffic 2 hours every day.
But 82000miles with stock pads its amazing!
Old Feb 12, 2009 | 09:52 AM
shoeys08dkcandygt's Avatar
shoeys08dkcandygt
thats amazing.
Old Feb 12, 2009 | 10:01 AM
d_ames117's Avatar
d_ames117
Thanks
Typically you'll need front pads before you need rear pads. So if you haven't replaced the front ones and they haven't told you that you need to, they're probably trying to squeeze you for money.
Dustin
Old Feb 12, 2009 | 10:10 AM
fakesnake's Avatar
fakesnake
Try Hawk ceramic high performance pads, they cure a lot of braking ills like pulling left or right, and last a long time. I have them on my car and they work great. Much better braking than stock.
Old Feb 12, 2009 | 11:28 AM
Nuke's Avatar
Nuke
I suppose I'm in for a shock when it comes time to replace brake pads on the Stang. All 6 of my Toyotas averaged about 120,000 miles per axle on pads.
Old Feb 12, 2009 | 11:41 AM
Smooth_J's Avatar
Smooth_J
I thought if you use ceramic pads on regular rotors you could warp the rotors (thats what i was told anyway).
