Temperature problem help!
Old Feb 13, 2009 | 11:58 AM
gnrpatience's Avatar
gnrpatience
Default Temperature problem help!
Hello Everbody,
So i took my pony into service 30000kms. I used 5w 40 full synthetic oil since thats the only Motorcraft have here in mexico, i took my pony on wednesday.
Yesterday at night under traffic conditions tempreature indicator went to high and i saw some anti freeze on the motor. So when i realize this i stopped the car and waited for it to went down, today in the morning the same thing so i decided to take it to the stealership.
So what could be happening with my car, the only difference is that i used Motorcrarft Full Syntethic 5w 40. Can this type of oil can cause this problem ?
What else can cause this problem ?
Old Feb 13, 2009 | 01:47 PM
Lethaldosage423's Avatar
Lethaldosage423
it shouldnt really be anything to do with your oil. Check your coolant level. It could possibly be a stuck thermostat.
when your car is getting hot, does your heater work in your car? If not its the thermostat. Simple change
Old Feb 13, 2009 | 03:27 PM
gnrpatience
Yes the heater works ok. I checked the coolant level and it was good.
Right now its on the delearship.
Old Feb 13, 2009 | 03:32 PM
owero01's Avatar
owero01
It could still be the thermostat or even the water pump.
Old Feb 13, 2009 | 04:25 PM
157dB's Avatar
157dB
Cut & Paste Expert
Or a faulty temperature sender.......
Is it physically hot?
Did it go into cooling failure limp home mode?
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
