My thoughts on Steeda UDP's/CMDP's
This morning I met up with Paul (one eyed *****) at his garage and we installed Steeda UDP's, Steeda CMDP's, a 180* T-Stat and some Redline Water Wetter. The install went very very quick. 3 hours to get everything in including a run to Discount Auto Parts for a T-Stat that would fit the housing. Started with taking out my WMS intake then the fan. Tried breaking the crank loose but it wouldn't budge so we sprayed penetrant and worked on getting the manifold off instead. Got that off, swapped the plates and swapped t-stats, got the manifold back on then swapped the pullies and buttoned that up. Went to flash the car and the cluster wouldn't light up so I knew the X-Cal blew a fuse. Replaced it and flashed the car and took it for a spin and everything checked out fine.
On my way home I got to really see what the car was like. Few things I noticed:
-On decel the car always made the blub....blub.....blub sound while just coasting in gear. Now it does it much quicker, seems to go blub..blub..blub. Less time in between the pulses and the pulses are much more aggressive.
-The car free revs easier. Makes rev matching when downshifting much easier then before.
-The car is way less stressed. On the highway in fifth the car doesn't lug anymore if I give it gas. Seems to run smoother and far better.
-As far as lower temps there is no proof to show if it worked or not. SCT doesn't support Windows Vista 64bit so I am not able to datalog at all which is unfortunate. The temps should be down by a good amount now so less heat soak at the track
-The car still trumpets the same amount, but the raspiness in the trumpeting died down. I think the rasp is caused by the motor working hard and struggling and now that it isn't as much it has calmed the rasp down considerably.
I would like to thank Paul for giving his time to help me install the parts and to congratulate him on the turbo stang. It's one sick ride and pulls like a freight train through the gears. Only got a short bit of video before the camera crapped out hopefully he will throw what we filmed up on here.
Kevo
Kevo
Lol I had met him before on the CFL cruise so I had seen his car pre-turbo.
TOMBSTANG- The reason I put it in was so that I dind't suffer from heatsoak at the strip. The S197 really start to lose ET's and dyno numbers from repeated abuse so I did this to prevent it. I also lowered my fan temps to accomodate as well.
My stock temp T-Stat was 192. The lower one opens sooner, letting the coolant sitting in the motor circulate to the radiator and cooling down before it hits a higher temp. Lowering the fan temps also allows them to cool down the coolant sooner. The Water Wetter is supposed to drop temps by about 10* by lowering the surface temp of the water allowing it to transfer heat better, at least in theory.
Chis, I was looking foward to you coming because I don't seem to remember you or your car fromt he CFL cruise. Guess I will see you another time. I'm hoping these mods drop me even closer to the 12's.
