NEED HELP!!! Messed up my TB
Ok so i decided to take my tb spacer off and decide to clean my tb while at it well now it idles hi and throttle seems to "stick" at higher rpms, How do i adjust it back???
Originally Posted by 06MUSTANGGT24V
(Post 5978252)
Im about to clean it this weekend..... Anybody can help here i dont want to cause problems after cleaning my TB. Thanks |
Did you use carb/brake cleaner? Because I heard those remove some sort of coating that's suposed to stay on the TB.
I used throttle body cleaner and had no problems. Also check for leaks in your CAI. |
Maybe try disconnecting the battery for 10 minutes so the PCM can relearn the idle?
tb cleaner is fine to use,but you cannot move the blade by hand! You have to turn the key on and have someone hold the gas pedal down and then clean it!There is away to reset it but i'm not sure you can do it without a scan tool!
Originally Posted by charliebrown266
(Post 5979189)
I just want to clarify, what cleaner did you use? Also, If you did screw up the TB you can get another one from the savage yard. Not sure how much, but I know its there.
Originally Posted by Smooth_J
(Post 5980741)
But it doesnt snap back all the way i can see where it is still open a lil bit? |
(Post 5981637)
It was carb cleaner! :(
But it doesnt snap back all the way i can see where it is still open a lil bit? NO! Then why the hell would you use carburetor cleaner on a throttle body? |
Because it's the same thing relabeled???? Hmm that could be why!! When I cleaned my TB I held the blades open by hand with a screwdriver wrapped in a rag, I had NO problems. Not sure why yours is sticking.. and the whole coating on the TB is a myth BTW
