shifting thud
Old Mar 8, 2009 | 08:11 PM
Smooth_J's Avatar
Smooth_J
Default shifting thud
I am not sure whats going on or it could be just be me, but virtually every time I shift I feel a thud in the back, is this the two piece drive shaft kicking around?
If it is, is there anyway to solve it besides switching over to a solid drive shaft?
Please let me know - thanks!
Old Mar 9, 2009 | 10:11 AM
Smooth_J's Avatar
Smooth_J
Please anyone?
Old Mar 9, 2009 | 10:17 AM
solaratomic's Avatar
solaratomic
Mine does it too, sometimes. I think as the two piece driveshaft gets some miles on it, it loosens up and starts making a little noise. If it's real pronounced you might want to drop it and check the u joints. I looked at them and they look like they have to be machined in...thanks Ford
Old Mar 9, 2009 | 10:49 AM
Smooth_J's Avatar
Smooth_J
I have around 1500 mi though :/ so I dunno
Old Mar 9, 2009 | 12:09 PM
svastano's Avatar
svastano
Smooth J,
I have the same problem on my V6. I an going to get an aluminum shaft before summer. to me this is just poor design on Ford's part.
Old Mar 9, 2009 | 09:01 PM
Lifter583's Avatar
Lifter583
Time for a 1 piece driveline...AND DONT CHEAP OUT ON IT!!
I put a Dynotech 3.5 aluminum on (from Brenspeed)I cant even begin to describe how much better it is then the stock 2 piece boat anchor!!
Old Mar 9, 2009 | 09:31 PM
Smooth_J's Avatar
Smooth_J
Hmm, don't I have to worry about vibrations and etc though?
Old Mar 9, 2009 | 09:53 PM
07musclemustang's Avatar
07musclemustang
yup probably the two piece thunk
Old Mar 10, 2009 | 06:02 PM
Lifter583's Avatar
Lifter583
I discussed the issue in depth with Seth at Brenspeed. The vibration problems are ALWAYS with the less expensive drivelines. They have never had a problem with any Dynotech, (rated to 900 HP) No screwing around with installation, direct bolt on. I could not be happier, as I said it made my car TOTALLY different, smooth,tight, positive shifts. (manual trans.)
Old Mar 10, 2009 | 06:45 PM
Smooth_J's Avatar
Smooth_J
Are you talking about this one?:
http://www.brenspeed.com/dshaft05gt.html
Also, is a loop required or no?
