How To Install Springs
That was a good link lostsoul thankyou what line of Eibach did you put on?Just wondering because I did go ahead and buy the panhard bar with mine.
I went with the eibach sports line.. Orion_240 is right about it being REAL low.. haha you might want to check out the H&Rs too.. being low is great for my bad boy turns.. but the ride is bumpy.. It all depended on what your looking for..plus it helps to upgrade the shocks too.. If I could do again I would get something not so low.. but then again.. I dont know how the ride is with a 1 inch drop. I hate sweating over bumps..hahah.. now I have to get big fat drag tired to bump me up a little.. but I guess it all works out.
I would go with a littl over an inch drop and get this camber kit for 40 bucks someone else posted. Dont know how well it works.. but I like the $40 part.. haha
http://www.specprod.com/PROD_DIR/PROD_PASSCAR.HTML
ORIGINAL: lostsoul
ORIGINAL: RICVA05
ORIGINAL: hawgman
And in your case, it is probably lower on the drivers side anyway
ORIGINAL: lostsoul
Hahaha.. thanks.. only a little lower on the driver side.. but I'm thinking about working on it... maybe... I sit in a chair for 13 hours a day
ahhhhhhhhhhhhhhhhh.. and I cant stop the overtime because I keep buying sheet. .. its a bad cycle.. over and over.. hummm
ORIGINAL: delurker
I lowered mine about 1.25" and I'm glad I installed an adjustable panhard rod.
ORIGINAL: RICVA05
Thanks for replying I was told that I should Install a adjustable panhard rod when I lowered the car glad to here someone else has already had it installed.
Thanks for the link, lostsoul! It wasn't as detailed as I would've liked, but I mainly wanted something to show whether or not it's easy. Looks like it is, so my sone and I will be busy this weekend!
I've got a set of ASA AR1s in black that I ordered from Tire Rack on the way. They should be here by the weekend, and since I've got to put those on anyway...
Hey, delurker, can I get a side shot of your car? What wheels are those you have on it? They look great from that angle.
I've got a set of ASA AR1s in black that I ordered from Tire Rack on the way. They should be here by the weekend, and since I've got to put those on anyway...Hey, delurker, can I get a side shot of your car? What wheels are those you have on it? They look great from that angle.
Sep 1, 2015 08:16 PM
