LCA WITH RELOC BRACKET INSTALL ?
Old Mar 12, 2009 | 12:43 PM
Blk06 Droptop's Avatar
Blk06 Droptop
Default LCA WITH RELOC BRACKET INSTALL ?
I AM GOING TO INSTALL BMR LCA WITH RELOC BRACKETS, THIS MAY BE A DUMB QUESTION BUT I HAD MY GEARS INSTALLED AFTER I WAS LOWERED, WILL CHANGING THE ANGLE OF THE LCAS CHANGE MY PINION ANGLE ? THUS CAUSING GEAR WINE, BECAUSE I DONT HAVE ANY GEAR WINE NOW AND WANT TO KEEP IT THAT WAY.
Old Mar 12, 2009 | 01:03 PM
nmd55's Avatar
nmd55
im seeing double!
Old Mar 12, 2009 | 01:20 PM
Blk06 Droptop
SORRY FOR THE DOUBLE POST MODS PLEASE DELETE
Old Mar 12, 2009 | 08:19 PM
owero01's Avatar
owero01
The relocation brackets will change the pinion angle. It may not be correct. I don't think it will affect the gear whine.
Old Mar 13, 2009 | 06:13 PM
miloman's Avatar
miloman
I don't see how the pinion angle will cause gear whine.
Old Mar 13, 2009 | 07:30 PM
zporta's Avatar
zporta
i dont think relo brackets will really change it...they will return the LCA's parallel 2 the ground like they were stock...adj. LCA's will change ur pinion angle...
Old Mar 13, 2009 | 10:57 PM
One Bad Stang's Avatar
One Bad Stang
oops, just read that this is a double post. --delete--
Old Mar 14, 2009 | 07:44 AM
ziperhead's Avatar
ziperhead
From what I understand and I an no expert
Altering the length of the LCA's will alter you pinion angle. The relocation brackets can change your instant center if not adjusted parallel to the ground and mess with your ride and traction
Ref: How to Make Your Car Handle by Fred Puhn
Old Mar 15, 2009 | 05:23 PM
tx_zstang's Avatar
tx_zstang
It depends on the relocation brackets. Theoretically, the brackets should not change the pinion angle, if their holes are aligned so that when the lca is lowered the holes line up properly. In reality, with welding brackets on (recommended; I even welded my CHE ones on), you should still check the pinion angle and see if it changed, and then adjust (UCA or LCAs) as needed.
Old Mar 15, 2009 | 10:12 PM
zporta's Avatar
zporta
if u think about it lowering ur car w/o changing 2 relo brackets should change ur pinion angle but then after addind the brackets it should come back 2 the stock angle...
