Webelectric sequentials
Old Mar 17, 2009 | 07:11 AM
antipeterleague's Avatar
antipeterleague
Default Webelectric sequentials
so i've had these on for a while now and no problems up until yesterday (or maybe earlier, i don't know) my friend who was following me told me that on my right tail light, the right panel didn't light up while signaling or braking. can anyone help me fix this?
Old Mar 17, 2009 | 07:17 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
was the signal indicator in the car going faster then when the left side was on? If so its a bulb or 2 or 3....check your connections and if nothing is obvious....call webelectrics and they will replace for free as it could be the module the controls the sequencing
Old Mar 17, 2009 | 07:21 AM
antipeterleague
well i was hoping someone would tell me how to reset it, cause i know you could do that though i forgot how. if that didn't work i was gonna call them.
Nuke's Avatar
Nuke
I recently had an issue with my drivers side not sequencing. My suggestions: Unplug the main harness and spray some contact cleaner or simply unplug and replug a few times to "wipe" (clean) the contacts.
If that doesn't work, then: Unplug each bulb and do the same as above.
If you're sequentials are less than 1 year old, you should be able to get a replacement set under warranty. AM sent me my replacement set at which time, during removal, I was finally able to get the original set to work. I ended up buying the "replacement" set for my g/f's V6.
Old Mar 17, 2009 | 07:23 AM
Nuke's Avatar
Nuke
I'd call webelectric for that info. I was told to turn the turn signal on for 15-20 minutes but that didn't do any good. But a hard reset done properly is a better 1st step than tearing into the rear panel if you don't have to.
Old Mar 17, 2009 | 07:41 AM
antipeterleague
thanks for all your help.
i was told in an email from them to check the bulb and then the connection to make sure no pinched wires are causing a short.
antipeterleague
woops
Old Mar 17, 2009 | 03:34 PM
mxg30's Avatar
mxg30
This was going to be my suggestion to you. Aren't the Webelectrics Lifetime warranty?
Old Mar 17, 2009 | 05:57 PM
antipeterleague
i hope so haha
Old Mar 17, 2009 | 09:20 PM
Lifter583's Avatar
Lifter583
Lifetime warranty: When it breaks, it's lifetime is over and so is the warranty!
