quick ? please
Old Mar 21, 2009 | 01:53 PM
deekum1627's Avatar
deekum1627
Default quick ? please
im goin to take my car to the dealer so they can see why my tire senor light is on are they goin to mess up the tuner i have on the car or no ? thanks guys
Old Mar 21, 2009 | 02:11 PM
157dB's Avatar
157dB
Cut & Paste Expert
Mmmmmmm, could be.
Or maybe not if you are one of the lucky ones.
There have been instances where
the PCM was flashed with the newest
revision of software. If so, your tune
will be gone and it wont run properly with
the CAI installed and a reflashed stock tune.
You do have the TPMS sensors installed in
your aftermarket rims, dont you?
Old Mar 21, 2009 | 02:32 PM
deekum1627's Avatar
deekum1627
yea i have them installed on my new rims
Old Mar 21, 2009 | 02:33 PM
deekum1627's Avatar
deekum1627
i guess ill put the stock intake back on and tune and then bring it in
Old Mar 21, 2009 | 02:48 PM
157dB's Avatar
157dB
Cut & Paste Expert
Whom installed them on your rims?
Some have been known to not use the 3M
adhesive tape under the cradle and the
sensor has spun or come loose.
Remove your tires one at a time and
shake them to see if you have a loose sensor
before taking it to the stealership because
they wont warranty aftermarket tire/rims
if they didnt sell/install them.
Maybe Diagnose The Problem yourself?
Old Mar 21, 2009 | 03:00 PM
deekum1627's Avatar
deekum1627
sounds good man also discount tire put the senors in for me now if they are all fine shopuld i take it to the dealership to program them
Old Mar 21, 2009 | 06:07 PM
157dB's Avatar
157dB
Cut & Paste Expert
If the sensors came on your stang OEM and were previously programmed
or 'trained' at the assembly plant before being shipped to the dealer,
then they should already be 'trained' and further training should not be needed.
If the sensors were purchased new from discount tire and the SJB does/can not
recognise the serialized coded transmission, (so other TPMS equipped stangs
at stop lights wont be read by your SJB) then they need to be trained at the stealership.
Old Mar 21, 2009 | 06:15 PM
deekum1627's Avatar
deekum1627
okay looks like ill go to the stealership and put the stock cai and tune back on while they do that so they dont f*ck nothgin up
Old Mar 21, 2009 | 07:25 PM
Stkjock's Avatar
Stkjock
Retired Mod
deek - tell the service writer not to let the Tech flash the car, and leave a not on the OBD port - "DO NOT FLASH PCM" and you'll be fine, I did that 2x when the car was in for a recall
Old Mar 21, 2009 | 07:57 PM
bodyman's Avatar
bodyman
why dont you take the car back to discount tire?
