cams vs. gears
Old Apr 13, 2009 | 06:05 PM
usc49erfan's Avatar
usc49erfan
Default cams vs. gears
my friend asked me the other day-what is better gears or cams? i said probably gears, i have them, but not a hundred percent sure because i have never had cams. any opinions? i think it is an apple v. oranges situation but just curious
Old Apr 13, 2009 | 06:12 PM
snkebitel's Avatar
snkebitel
gears makes you think your fast enough to chase that corvette around town. Cams put you a little closer to catching him.
Old Apr 13, 2009 | 06:35 PM
Black Mamba GTT's Avatar
Black Mamba GTT
+1 haha
Old Apr 13, 2009 | 07:53 PM
SirKnightTG's Avatar
SirKnightTG
With a lot of cams (at least the ones that make good gains like Comps) you will need gears with them as cams will lose a little low end power to gain more upper end.
I'd say get gears first then cams. That's my plan.
Old Apr 13, 2009 | 08:19 PM
kingsofcrunk's Avatar
kingsofcrunk
Cams actually gain power, gears only distribute what you already had to different ranges.
Old Apr 13, 2009 | 08:24 PM
Legion5's Avatar
Legion5
removed
Old Apr 13, 2009 | 08:35 PM
Mishri's Avatar
Mishri
Mish-ogynist
wow.. legion5.. I always wonder how you find such arbritary figures.. amazing.. (how arrogant does someone have to be to quote themselves in their sig?)
figure cams can be good to up to 20-30rwhp/tq.. and 4.10s shave off about .3 secs I believe(correct me if i'm wrong) from 1/4 mile time.. so.. pretty close for performance gains. Kind of depends on what he wants and what type of driving he does.
Old Apr 13, 2009 | 08:46 PM
SirKnightTG
Cams are NOT better on the street if you are under geared (stock gears). If they lose low end to gain high end (and they usually do), it will be annoying (and slower) on the street in traffic until you "gear up." Even if you don't lose any or much down low, the gain is going to be up really high and you'll need to gears to get up there quickly to use the new power.
The truth is, they both go together but if you are going to pick one and the other later, it makes more sense to choose gears first.
Old Apr 13, 2009 | 08:57 PM
Legion5's Avatar
Legion5
No problem. I've deleted my post. Do your own ****ing dyno chart math:
http://media.photobucket.com/image/t...p/SCAN0003.jpg
http://www.americantorque.com/graph-rpm-vs-speed/
http://www.hillerford.com/resource_l...stangspecs.htm
Far be it for me to be called arbitrary when I do math based on engineering, which I mentioned as being my source, to get an exact number, and you're saying "correct me if I'm wrong".
Old Apr 13, 2009 | 09:00 PM
kingsofcrunk
Your still a douche for quoting yourself in your sig
