header sealant
Old Apr 16, 2009 | 10:52 PM
MadMike1337's Avatar
MadMike1337
Default header sealant
hey guys im wondering if it would be a good idea to use some high temp header sealant when i put my new headers on. when i do this to i put the sealant on both sides the gasket? i plan to use the stock gasket and locktite on the header bolts when i bolt on the parts. i wnat to do it right the first time and not have to worry about a leak.
thanks
Old Apr 16, 2009 | 11:05 PM
jahudso2's Avatar
jahudso2
I got copper RTV from advance auto parts and put it on both sides of the gasket and on the header mating flange around the ports. No leaks so far... It also helps to use the RTV to make the gaskets stick to the cylinder head or the header as you try to install the header on the car. Otherwise, its impossible to keep those stupid gaskets in place.
Old Apr 16, 2009 | 11:28 PM
KLO's Avatar
KLO
Loctite on the headers bolts? Whoa...no... Use some antisieze on them to make sure you can get them back out years down the road, and toqrue the bolts. You should be good at that point.
Old Apr 16, 2009 | 11:34 PM
antonio1988's Avatar
antonio1988
stage 8 locking header bolts and 3 months and 4,500 miles later, no complaints and even better no leaks
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Roxon68
Mar 17, 2016 08:13 PM
junior04
Sep 28, 2015 10:53 AM
trashxtrash
Sep 20, 2015 10:49 PM
BrantleyS550
Sep 14, 2015 04:18 PM
