Blacking out behind the grille?
Has anyone done this that they have pictures of or anything?
I've got a new grille in the mail, so I figured I might black out the painted section behind the grille when I swap them (car is white, so that shows up quite clearly behind the honeycomb grille.) I'm just not sure if it's worth the effort, or if it can be done cleanly while just the grille is out (as opposed to having to take off the whole front bumper cover or whatever.)
Anyone around here done this? (I remember seeing a write-up about it here before, but that was probably at least a year ago and I can't find anything in the search.)
I hid my fogs behind the grille and use black window screen material to hide how I mounted them. I also used black paint to protect part of the radiator support that I had to cut out since the lights are mounted in the center. I guess where I'm going with this is... Paint it black and if you don't want to risk any over spray then brush it. Good Luck and post pics.
When I got the Agent 47 grille I painted that part flat black but as you can see in the pic it still shows. The radiator also shows up a lot. If I take off the grille again for any reason I'm going to paint the radiator. I've been told not do it but Eastwood has a special Rad paint that won't ruin the cooling function.
Check out the link.
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Check out the link.
