another JBA instal issue. im stuck again
yup im stuck again. i got the driver side bolted up now im having a problem with the pass side. how the hell do i get the new one in?! its immpossible!!! i got the old one out ok no problem. i removed the starter and MM with out any problems but when i go to put the new one in it gets stuck on the tranny where the starter bolts up and on the k looking thing.
any suggestions...
any suggestions...
You have to insert it from behind the black k thing. It wont fit in the hole closest to the front of the car. Also orient it so that it is like its going to be installed, and it will go in. I could never get it through the hole in front of the black cross member.
still lost on what your saying. i tried inserting it through the rear foward. the are near the starter is where i tried to get it through. did u have to move the motor slightly to the driver side? i really dont wnat to tow it out of my garage if i cnat do this =(
From the bottom. BUt first thing. raise the engine and try and get it to fit, if not then raise the engine a little bit more. Or if you have a friend, have him move the engine over to the side a little and it will give you a lot more room to fit in.
i tried fitting it in and then raising the motor slightly with each try and no luck. did u have this problem?
Yeah I did have the same exact problem as you. Took me like 10-20 minutes to figure it out. If i remember correctly, I raised my engine pretty damn high. just about until the end of the plenum cover was touching the rear engine bay. I also had my friend move the engine over to the driver side as much as possible while i wiggled in the headers.
Get another pair of hands and it'll be like 100000x times easier
