Warm Air On Driver's Side
Yeah, bad beans...
Assuming you don't have your right dash dial on the floor position, it could be the trap doors not working properly on the ventilation system.
They could be sticking a little.
If you have that dial on the 0 position (vertical), you shouldn't have any air circulating in the car with the windows up...
I've noticed on mine if I run the heater control in the O position it radiates a lot of heat out of the dash vents, even with the temp. control all the way down. I just assumed it was under hood heat radiating through he system.
If I turn the control to the dash vent position it brings coooler air through them and then all is fine. Took me awhile to figure out why I was always "hot". LOL
Not a problem for anyone else???
