Dyno Tuned!!!
Old May 5, 2009 | 04:06 PM
StangEatsRice's Avatar
StangEatsRice
Default Dyno Tuned!!!
Car got tuned at PSI Motorsports in New Tripoli, PA. Only mods are pypes midmuffler and o/r x and a jlt2. I never had a email tune for the intake so i had to wait to put it on until it got dynoed. Cars a beast now. It made 303rwhp@5900rpm and 300rwtq@4700rpm /w 93 octane. First pull with the intake was 291rwhp and 279 rwtq, a/f was way off. You guys think these are correct/good numbers and my goal is 12.8's. Sound like i'll hit it on radials?
Attached Thumbnails Dyno Tuned!!!-picture-001.jpg   Dyno Tuned!!!-picture-002.jpg   Dyno Tuned!!!-picture.jpg
Old May 5, 2009 | 04:16 PM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
What do you hit now?(1/4 mile) I doubt you can break into 12's but this is not my area of expertise at all!...great numbers though!
Old May 5, 2009 | 04:17 PM
StangEatsRice
Haven't hit the track yet. Still trying to get my hands on 2 rims to mount strip only tires to.
Old May 5, 2009 | 04:20 PM
05 Mustang's Avatar
05 Mustang
not 100% sure, but based on your mods I would say around 13.1 or 13.2...the only reason I say this is because I have freinds with similiar set-ups and that's about the best they could do..
Old May 5, 2009 | 04:34 PM
whtcanbrwnd04u's Avatar
whtcanbrwnd04u
Those are good numbers for your mods. I think a set of gears and tires and 12s should be no problem.
Old May 5, 2009 | 04:43 PM
Nuke's Avatar
Nuke
Definately good numbers for CAI, tune and X-pipe. Not too many can break 300 RWHP with just those.
Old May 5, 2009 | 04:53 PM
Chris07GT's Avatar
Chris07GT
I think a 12.8 is going to be tough. I'd say more likely in the 13.2 range. Let us know how it goes when you get it to the track!
Old May 5, 2009 | 05:03 PM
VanWilder's Avatar
VanWilder
if you can drive you can definately hit it with some tires...I have basically the same setup and on a superflo dyno I only put down 280hp and 290tq...was told by Doug at Bama that on a dynojet I should hit right around 300whp because a superflo reads really low...as you can see from my sig with tune/intake, o/r x, and tires I ran a 12.76 @ 108.88...and it has more in it...my first pass I let off at the 1000 ft and ran a 12.86 @ only 95 so I had 14 mph difference which I would assume would have gotten me somewhere in the 12.60s...good luck man!! btw what is your elevation because that plays a big roll in how good you will run?? the track I run at is at 1150 ft
Old May 5, 2009 | 07:37 PM
StangEatsRice
There are 3 tracks i run at, Atco in nj, Island in nj, and Maple Grove in pa. I'm thinking with m and h drag radials at atco i can hit 12.8. Car is dead even with a intake/exhaust 6.0 gto from a roll.
Old May 5, 2009 | 07:51 PM
mikeysGT's Avatar
mikeysGT
thinking you might hit a 13.0 or a 12.9 on m/h's. i'm right around there with 300hp on motor without the nitrous.
