Mine started doing the same thing after about a week of driving. The over axle pipes had become a little bit loose and the drivers side was rubbing on the panhard bar. I just loosened the clamp, pushed up the pipe, and then retightened. No more noise since then. In your case I would get back under the car and inspect. Probably nothing more than a little adjustment will be needed.
